Newb Q: what do you use to re-wrap the wire loom near the ERG pipes? (2 Viewers)
I used "header/exhaust" wrap that you can get at summit or any other performance type shop. I also used the metal ties to secure the wrap.
Jack
x2, done this repair twice (on two different rigs).
If you were to go to a speed/performance shop, you may be able to pick up the short amount you need for almost free, I'd bet.
I used stainless wire to hold mine.
Dan.
NO help here...
..but welcome to MUD :flipoff2:
Dan.
Do you wrap the wire loom, or the ERG pipes, or both?
Thanks!
I had to really reduce this photo to post it here but this is what we did - DEI (Design Engineering Incorporated) hi-tech / hi-temp heat shielding on the outside, DEI heat sheath sleeve on the inside and DEI stainless steel wire ties holding it tightly together. It has held up really well and I am sure it is protecting the loom from the EGR heat. HTH. :cheers:
Hey turbo,
I noticed those two cylinders at the rear are lookin a bit more worn than the one's up front.
You can just flip your engine around to balance that out................................:hillbilly:
:grinpimp:
Hey turbo,
:grinpimp:
Its just the way the flash hit the surfaces there. Trust me, ANY excuse to buy a brand new block from Dan the Man and I woulda dun it! :D :flipoff2: :D
Well see, there ya go..! Just show him the picture.. and whoever else you have to convince that your in need of a new engine.
The whole flash thingy ..we'll just keep that between me & you :grinpimp:
:beer:
I used some tape...got it from Summit Racing for a reasonable price....
-o-
ps: I also got rid of the EGR valve assy. completely.
