New TRD Oil Filters
Discussion in '80-Series Tech' started by BigMac, May 2, 2003.
  1. BigMac
    BigMac SILVER Star
    216
    Mar 27, 2003
    Lompoc, CA
    CruiserDan & company:
    What's the skinny? Of course I'm such a newbie this could be old news to you guys. **********************************************
    "TRD is pleased to introduce a new line of TRD Performance Oil Filters for Toyota and Lexus vehicles. Constructed of a sturdy steel outer shell, the oil filters feature arch-pleated media for low flow resistance. A combination silicone by-pass and anti-drain back valve allows for good lubrication during cold-start without allowing dirty oil back into the engine after shutdown. Additionally, the less than 2-psi pressure drop offers better engine protection."
    http://www.partznet.com/trdoilfilters.html
    Usual disclaimer - tango no interest whatsoever.
  2. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    interesting.
    I'm sticking with the several boxes I have of the 20004 though. :D
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Cap,
    I saw the intro just before I went to Southern Utah for a week. Just got back tonite (1000 miles round trip) I have yet to see one in person. It would be hard to beat the 90915-20004 filter. I will get one and cut it up and see what's inside.
    Regards, Dan :beer:
  4. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    The 00602-90915-004 is small but a flat seal unlike the yzzb5 one has a round (cable like) seal. I will try it on the fj60 as the OEM doesn't seal (it leaks). I hope it can handle 20w50 oil.
    kurt
  5. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Kurt,
    >> I will try it on the fj60 as the OEM doesn't seal (it leaks) <<
    Are you sure you have a Land Cruiser? It sounds like someone sold you a Land Rover. Everything on your truck leaks and the OEM parts don't fit. Can you post a picture so we are sure you have a Land Cruiser? :G
    -B-
  6. cruiserdan
    20,564
    2,891
    Mar 27, 2003
    Now, now, Mr Wulf,......aren't we being just a bit hard on our friend? :dunno: Not everyone can properly tighten an oil filter. :ugh:
  7. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Kurt-You do smear the seal on the filter with oil before you screw it down right?
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    The filter on the 80 doesn't leak!!!
    That is the only leak on the 60. I fixed all the other leaks.
    The only leaks on the 80 NOW is the oil pan and some where on the timing chain cover.
    kurt
  9. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    B
    This is what I bought. I was told it was a LC.
    kurt
  10. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    looks like a cruiser to me? :G
  11. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Kurt,
    You overdid it a bit on the resizing with IrfanView. Maybe a teensy bit bigger if you want us to believe that's a Cruiser and not a Rover. :G
    -B-
  12. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    This is the side view.
    kurt
  13. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Kurt,
    The next time that thing leaks touch your finger in the fluid and taste it and smell it. It could be grease, coolant, oil, water, or ATF. Let us know what you taste and smell and we can help identify what is leaking.   :G
    BTW, you're still struggling with pic resizing. RTFM.
    -B-
  14. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I don't know what I am doing. I need Pic101. How did you do that to my pic?
    kurt
  15. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Kurt,
    >> How did you do that to my pic? <<
    Whadda you mean *your* pic? It's mine now!
    Go outside and check underneath your FJ60. You'll find it no longer leaks from the oil filter. I fixed that for you too.
    You forgot to put a little oil on the seal and it was over-tightened. It's fixed now but next time use an OEM filter and follow the directions on the box. Tighten until the gasket touches, then 3/4 turn and STOP.
    :beer:
    -B-
  16. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    No can do. It is sold. The guy is comming on friday to pick it up.
    Now I can't test the TRD filter :cry:
  17. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    :dunno:
    So has anyone tried the TRD filter?
    I would be interested to know if there is any improvement on a cold start?
    I am still bothered by the dry "rattle" @ start up.
    C-Dan,
    Have you had a chance to disect one yet?
    Eduardo
  18. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I still have the TRD filter and will use it on the 80. I don't have a oil rattle at start up now. I am using the yzzb5 filter.
    kurt
  19. BMT
    BMT
    325
    Apr 1, 2003
    Went to change my oil last weekend and figured I will try the TRD filter. Went to my dealer, sat there for 15 minutes while the parts guy searched through book after book and then told me $13.95 special order. I guess I will run a K&N for another 3,000mi. :givecrap:
  20. RavenTai
    RavenTai
    6,048
    16
    Nov 16, 2003
    Dixie co. Florida
    hmm reading this the filter is good:
    "The alternative to this is the TRD filter part# 00602-90915-007. The TRD filter is the essentially the same as the old 20004 and is priced the same also ($7.58)."
    http://www.intellexual.net/faq.html#131
    but you guys say the gasket is different? so it cannot be identical, if it has the same odd ball media and high quality bypass valve as the discontinued 20004 I'll use them,
