Received my carb in Alaska today. Quick shipping, thanks.
Yes that is correct. I have plenty of carbs. I should be in stock for quite a while.
My carb and dizzy arrived! Thanks!
I ran into a few snags while installing the new parts.
1. My fuel line entered the original carb on the passenger side. Your carb's fuel inlet is on the front. I can bend the stock hard line, or cut it, and insert a section of flexible line . . .. What have you seen that works best? Bend the line. Do it gently bending a little at a time.
2. The new carburetor contacts a hose exiting the front of the carb spacer. (See pics.) Cut the shaft about an inch away from the carb.
Should I cut and plug the line exiting the spacer? Should I cut the long shaft exiting the carb, and leave the hose attached? The shaft exiting the carb does seem to be longer than necessary. Thoughts?
3. Should there have been a male connector for the ignition/fuel solenoid? The carb has the female side attached, but there wasn't a male side to connect to my harness. You have two options you can cut the end off the new solenoid and put your old connector or you can attach a female spade on your harness.
4. Where should I connect the wires from your dizzy? Black wire goes to the negative side of the coil. Red wire goes to one side of ballast resistor. Power wire from your stock harness also attaches to this terminal. Short jumper wire from other end of ballast resistor to + terminal on coil. That is it.
I know these questions might have been asked before, and the answers are probably somewhere in the sixty-eight pages of this thread, but, I don't have the time to read all sixty-eight pages. Plus, I just spent $500+ dollars, so I figure you don't mind helping me with a few questions.
Thanks
