- Joined
- Jul 22, 2012
- Threads
- 484
- Messages
- 14,261
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Thought I would document my progress for what will (when complete) be the most custom (and coolest IMO) part of my rig.
My FJ62 is getting (behind the rebuilt 3FE) a Dodge Standard Duty (gas) NV4500 5-speed transmission, the front half of an NP203 transfer case (which is the reduction/Hi-Low portion) and then a stock FJ62 transfer case converted from vacuum shift to manual shift.
3-Speed Toyota bellhousing is on its way from New York (Free +shipping!!) which will allow me to use the Advance Adapters SM465-to-NV4500 adapter plate.
I just claimed a rebuilt and powder coated NP203 already drilled so it bolts to the NV4500. And it includes an adapter to the Split Case. And did I mention that the whole setup was only 500 bucks? The adapter alone costs more than that. So that was a sweet deal.
Lastly my original plan was to just bolt up a Dana 300 and eventually Atlas behind the NV4500, however I got the 203 and adapter for less then a set of Lo-Max 300 gears and a doubler is way cooler anyways.
Now, I already have a split-case in the truck, pre-10/82 the earliest iteration with the 34mm idler shaft and no provision for the h55f's extra bolt, the reason I have it is that Eric (wheelin62) went to an H55f (the logical thing to do) and couldn't use this case. So I have it.
A key difference between the 60 and 62 case is that the 62 split case has bearings supporting the gears instead of bushings And it has a lower Low range (by a whole 0.02:1!!). So I'm going to go with that.
TLDR - I do things the hard way.
