Never Used Alcan FJ40 Springs, and Detroit Hysteer axle in CO
Discussion in 'For Sale - Parts' started by jdcullen, Aug 29, 2003.
  1. jdcullen
    jdcullen
    1
    Aug 29, 2003
    Front and rear Alcan spring set for sale. Asking $450 for the set. Never used. These were custom built in March 2003 to the following specifications:
    Front Spring Packs:
    -overall length = 48" measured along curvature of spring
    -center of front eye to center pin = 24"
    -center pin to rear eye center = 24"
    -8 leaves
    -designed for spring over conversion
    -designed for rock crawling and flexible with anti wrap leaf
    -military wrap ends (double)
    -spring rates tailored to small block chevy weight + winch+ 50 lbs bumper
    Rear Spring Packs
    -overall length = 49" measured along curvature of spring
    -center of front eye to center pin = 23"
    -center pin to rear eye center = 26"
    -7 leaves
    -spring rates tailored to weight equivalent of soft top, passenger, and additional 150lbs +/- gear.
    These springs as you know are manufactured in Grand Junction, CO (check out Alcan Spring's Website if unfamiliar)
    When set up on my rig, they pushed my rear wheels back 3" and my front wheels forward 4" for a wheelbase of 97" versus the stock 90" wheelbase.
    Total lift is perfect to clear 35" tires and maybe 37" tires with some rear fender trimming according to a buddies rig with similar setup.
    Also have fabbed front bumper/spring relocator/ hanger I made to hang the front springs. It requires removal of all existing front bumper, and shackles as this also provides a shackle reversal setup. It is a bolt in front end that can be later welded. Also have the similar setup for the rear. They both allow fine tuning of shackle angles prior to welding.
    custom fabrication to insert shackles through the front frame rails would still be required.
    rear springs still mount to original spring hanger, with shackles moved rearward.
    This setup may likely require steering mods depending, but nothing out of the ordinary to any cruiser owner.
    Intention was to build a buggy from the ground up, I was part way there and decided otherwise.
    Also have for sale
    $75 -good stock radiator and shroud
    $25 ea - front and rear stock driveshafts
    $30 ea - L and R rear axle shafts
    $250 - excellent stock rear axle open diff 4.10s good drums and good cyls with perches set up for spring over
    $1500 - front axle with spankin new 81 lc vented rotors, minituck birfs and knuckles, spindles, new detroit locker, all pro hy steer arms, all new seals blah blah blah
    need to drum up some cashola for new project... truck building attention defecit... somethins
    located between utah border and Vail, CO on I70
    jd_cullen@hotmail.com
  2. timp
    timp
    6
    Oct 7, 2003
    Do you still have the springs for sale?
  3. Cruiserdrew
    Cruiserdrew SILVER Star
    13,564
    1,491
    Mar 15, 2003
    Sacramento, CA
    I would like the driveshafts-what year are they from? My zip is 95864-can you estimate shipping?
    Thanks
  4. tomsryd
    tomsryd Fleet Superintendent *with no time for fun SILVER Star
    185
    8
    Nov 7, 2002
    Hanford,Ca.
    [quote author=timp link=board=5;threadid=4799;start=msg64709#msg64709 date=1069181883]
    [/quote] The springs are on sold :D
  5. FJ40Dude75
    FJ40Dude75
    248
    Nov 12, 2002
    how much for the hysteer arms
