After a month of reading a gazillion threads on starter issues on my 95 LC, I finally was able to narrow down my problem to a corroded wire end (black with white stripe) at the neutral safety switch (NSS) connector located on the transmission housing. Keep in mind that I am not even considered a 1/4 of a when it comes to being a mechanic. Anyhow, the first pic shows the location of the NSS connector and black with white stripe wire in question. I have read several threads to check the black with red stripe and black with white stripe for corrosion. In my case the black with white stripe wire end is corroded to a point where there is no metal connector that would attach to the plastic connector as depicted on the second pic.
Which brings me to my question, how have others repaired the corroded wire? Should I just put another end on the wire and connect back to the plastic harness? I've read that some people have solder the wire but I'm not too sure how that would be done. Should I also replace the plastic wire harness? Does anybody have the part number? I think I'm over thinking the issue. It must be from the lack of driving my LC. Anyways, any suggestions would be appreciated
