Need info on shackle reversal
Discussion in '40- & 55-Series Tech' started by scruffydawg, Feb 16, 2003.
  1. scruffydawg
    scruffydawg
    16
    Jan 19, 2003
    I have a fj62 and i'm planning on putting a 2" OME lift on and also thinking about doing the SR at the same time but I can't find much info on the SR. &nbsp:Does it help with the suspension ride or is it better to leave it alone? I am looking at wheels and tires also. I like the fat tires and the size i'm looking at is 33x13.5 but not sure on 15" or 16". It's hard to find very many wheels 15x10 with 3.5 backspacing so I'm thinking about 16x10 I think I can go with more of a backspacing but not sure. And how much lift I need for the 16". Any input would help. THANKS !!!!!
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    Rim size has no effect on tire size....33x16 versus 33x15 will both be 33" tall, or close. 16" will offer more clearance at the caliper, but sometimes the interference is with the spokes of the rim as well (a bit of grinding on the calipers fixed it on my FJ40)
    IMO, for a 33x12.5, go with a 8"-9" wide rim. 10" is more likely to hit the outer fender edges, since the 2" of width over the 8" rim is added at the outside edge.
    Read the writeups and info in the tech section on reversals. IMO, they are not necessary and make a negligible change in handling/ride.
  3. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    I think this is true more so with the 60-62's then the 40's, but just IMO
  4. Corbet
    Corbet Speski OffRoad LTD. Supporting Vendor
    3,731
    616
    Oct 22, 2002
    Durango, Colorado
    I have had a SR done on my 76 FJ40. 2" OME at same time. I'm running 33 x 12.5 GY MTRs on 15 x 10 eagle alloys. The difference between the stock suspension and SR/OME was night and day. However I can't tell you which one had the greatest effect. The 33s do rub the outside front fenders ocasionally off road. The calipers did need a little machining (hand held grinder) to clear the wheels.
  5. scruffydawg
    scruffydawg
    16
    Jan 19, 2003
    Thanks for the info!!!! Will the 33" fit with just the 2" OME lift??
  6. Corbet
    3,731
    616
    Oct 22, 2002
    Durango, Colorado
    After I posted my info I realized you were talking about a FJ62 verse my 40. But as far as I know 33 x 9.5s will fit with just the 2"OME. 12.5s will probably rub a little
