Sensor 1 is NOT the knock sensor, but the ECT (engine coolant temperature) Sender gauge. The knock sensor is not in the picture. It is located above & to the right of the oil filter, looking at it from the drivers side of the engine bay. Sensors left to right: ECT sender gauge, ECT Cut switch, ECT sensor.There are 4 sensors in this photo, all inline.
Sensor 1 (leftmost) is front knock sensor. Only one cable goes from it. Sensor 4 (rightmost) is back knock sensor. Also needs one cable.
Both middle sensors are yet to be determined by someone else. I suspect the temp sensor is one of them.
My understanding is that it cuts off the A/C compressor when coolant temps are too high (I believe around 226 degrees F).What does the ECT cut switch do? I get the sender feeds the dash and the ECT that feeds the ECU variable resistance to help decide how much fuel to use.
Thanks in advance!
Correct.
Disables the A/C compressor to prevent further thermal strain on the engine/cooling system. It (compressor) will kick back on automatically when temps recede to approx. 216°F
