narrowing the ford 9"
Discussion in '40- & 55-Series Tech' started by rusmannx, Sep 5, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    ok, this axle has got me all interested, but i can't find a single article on the net abot the process of narrowing one of these axles.
    if any of you know where to find some info i would appreciate it.
    i've already found tons of upgrade and tech articles on this axle, as well as specs and data sheet.
    i'm just looking for what goes into narrowing.
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Drag racers use the 9" religiously. Try that venue. If you go 9" with stock t-case you can shorten the righthand side only and just buy one axle shaft.
  3. kstatecruiser
    kstatecruiser
    94
    Oct 25, 2002
    Colton, CA
    If memory serves me right, I think Currie makes a narrow 9-incher for heeps. I don't know if they make the whole axle or just narrow a donor 9-incher.
    Scott
  4. cruiserrg
    cruiserrg
    306
    Feb 11, 2002
    Mankato, MN
    Narrowing a 9" effectively will require a jig, basically pucks that fit in where the bearing is that has holes to slide a very straight bar through them, and then another set of pucks that will bolt the flanges to and slide over the same bar. This is to keep the axle straight. Ford 9" housings are fabbed steel and would take well to a sleaving type narrow job.
    There are places you can get a housing made to size. Might be a good option as you can get it braced and stronger. If using stock I would try to look for a truck housing they have more material around the differential for strength.
  5. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Go to a bunch of local HotRodders, If you don't think you know any, go to the nearest small town. The 9" Ford is the most desirable rearend for ALL the rodders, even the ones running GM powerplants. They narrow them all the time for model A's.
    I've seen it done and it is not that big a deal. Most have the axles professionally done by a driveline shop, there again, not that expensive. The housings are no more difficult to do that a cut-and-turn.
    Ed Long :)
  6. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    curry narrowed my 9"they do and have anything for 9" and dana axles
  7. dylan
    dylan
    246
    Dec 23, 2002
    older broncos would probably be the right width any ways
  8. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    can you give me an estimate one the cost of this (narrowing housing and shafts)?
    i looked at my friend 77, but the center section was on the wrong side (towards driver side)
  9. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    [quote author=rusmannx link=board=1;threadid=4975;start=msg40495#msg40495 date=1063340495]
    i looked at my friend 77, but the center section was on the wrong side (towards driver side)[/quote]With a few mods the housing can be flipped to put the pumpkin on the right.
  10. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    does this lower the pinion or anything like that?
  11. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    The Ford 9" already has the lowest pinion of all. Currie has a hybrid with some 8.8 high pinion stuff but as they (Currie) say "medium to light" vehicles. I don't consider the TLC a light vehicle.
  12. hendo
    hendo
    181
    Sep 10, 2003
    san fernando valley
    currie charged me about $1200.00 for shortening, rear disc,new inner axles high strength,bearins etc
