My seat wont adjust to move backwards anyone know how to fix it?
Discussion in '80-Series Tech' started by mileslaughlin, Nov 29, 2011.
  1. mileslaughlin
    mileslaughlin
    18
    Sep 7, 2011
    Johns Creek, GA
    My passenger front seat wont move backwards, it moves forward fine but wont move backwards once it has gone forward anyone know how to fix it?
  2. Memphisacc
    Memphisacc
    164
    1
    Feb 18, 2010
    Memphis, TN
    check the shaft that connects the seat motors. the end piece that holds them together sometimes can come apart, but can be fixed with a little persuasion. If just one of the shafts falls out / breaks it'll still pull the seat forward but not have the juice to push it back on the two screws. Easiest way to do this is to pull the seat out. This is whats happened to mine before, but it could be the motors burnt out or something else.
  3. wareagleash
    wareagleash
    53
    Jun 25, 2011
    Chattanooga, TN
  4. mileslaughlin
    mileslaughlin
    18
    Sep 7, 2011
    Johns Creek, GA
    i dont think the motors broken because when i push the knob back it tries to move backwards but doesnt go anywhere, ill pull the seat out to take a look
  5. MAD MARK 80
    MAD MARK 80
    249
    1
    Feb 27, 2011
    I had a same problem, It was white little cap missing, motor turns other side rod but not the one side cap missing, basically just one rod moved till seat got crooked enough won't move anymore.
    I ordered cap from vender also member here and problem solved, I added hot glue over it to secure it won't fail off again.
    stevenmichael likes this.
