So I changed out few these now and just thought I'd share my experiences doing so. I was draining the block and rad so did it for s*** and giggles.
1. Drain block and rad
2. I then pulled fhh off the phh tube
3. Pulled top tube bolt next
4. I have the 2 bolt in at the middle of the tube still, took 12mm gear wrench coming from underneath thru wheel well and loosened but left in.
5. Used a good size hook pick for the cotter pin clamp.
Then razor blade off old hose
6. Rotate pipe to the side insert new hose to the block, rotate pipe back to position and got hose somewhat started. I spit on those hoses to make them slide easier. Once hose is close l pushed the pipe putting the hose on.
7. Tighten up some clamps add coolant
Took me a hr for whole job and just left the 2 bolt loose in the head and tightened up the top bolt .
