My mirror is loose and it's very annoying...
Discussion in '80-Series Tech' started by alex909, Sep 13, 2003.
  1. alex909
    alex909
    2
    Sep 13, 2003
    Hi,
    This is my first post here and I'm hoping that someone can help me. I have a 1994 LC and recently, the glass part of the side view mirror has come a little loose and shakes. Is this something that is typical and can be fixed without buying a whole new mirror unit? If so, what's the fix and how hard is it? Thanks a lot for the help!
    Alex
  2. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Tighten the screw at the bottom of the housing. When that doesn't work, pull the glass, put some RTV on the broken tabs and re-install. If you end up buying a new mirror (cha-ching!), put RTV on the tabs.
    Suffice to say, Toyota screwed up on the 80 series mirror design.
  3. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    ditto on tightening the screws, if the tabs are broken off on the back of the mirror, you can epoxy a washer on it to hold in place.
    new mirror is about $250 (was missing my mirror piece and had to buy one just to get it)
  4. alex909
    alex909
    2
    Sep 13, 2003
    Wow, thank you so much for replying so quickly. Well here's an embarassing follow up question to ask you, how do I get the mirror housing off so that I can see the mirror mechanism. Thanks again!
    Alex
  5. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    unscrew the bottom screw, then push up and in on the mirror- it sits on two plastic tabs, which is what tends to break off, and is held in on the bottom by the screw.
    if you ned to take it out, youll have to undo the electricsl.
    try tightening the screw first though
  6. RWD
    RWD
    149
    Mar 15, 2002
    south burbs of Chicago
    Here's a little write-up on the mirror thing:
    LINK
  7. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Is it recommended to apply RTV to the tabs as a preventative?
    -B-
  8. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,566
    2,892
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    B-,
    It certainly would not hurt anything. The mirror would be more difficult to take apart in future but as replacement guts are not sold I don't think that would be an issue. If you needed to do more than fix the loose head you would not be able to buy replacement pieces anyway.
    D-
  9. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    [quote author=Beowulf link=board=2;threadid=5253;start=msg41122#msg41122 date=1063558894]
    -B-
    [/quote]
    yes
  10. IdahoDoug
    IdahoDoug
    8,800
    92
    Aug 9, 2003
    I did a low-tech fix after tightening a few times. One day on a road trip, I found a few inches of black foam with adhesive on one side. Happened to be looking at the mirror, so it was clearly intended to be. Tore the foam into 1 inch strips which I wedged in the gap between the mirror edge and the housing, trying to maintain the mirror's position. Voila! Zero mirror movement and the black foam things virtually disappear. The mirror can still move a bit, but my wife and I like it in the same spot (passenger side) so it doesn't need to. That was about 4 years ago and I've forgotten all about it except when I'm looking at the perfectly stable image.
    IdahoDoug
  11. WolfpackTLC
    WolfpackTLC
    250
    Aug 4, 2003
    Central NC
    Beo-
    I love your quote. Me 10!
    J
  12. Beowulf
    Beowulf
    12,526
    30
    Mar 27, 2003
    J
    Only 1 in 1010 will get it. The other 1001 think we must be crazy.
    :D
    -B-
  13. DanKunz
    DanKunz SILVER Star
    8,864
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    010110010110111101110101001000000111001101110101011000110110101100100001
