Could you wire them like the Audi to function as drl and a signal light???
i'm looking at tackling this project. I have the lights sitting here on the bench.
Hate to ask this question and sound dumb, but what wiring are you guys wiring these into? I would like them to turn on when i switch the running lights on.
OK, so it sounds like my best option will be to wire them up to a switch in the cab so i can turn them off and on when i want.
Just curious WildYoats, any plans to make a bracket for the 4bulb version for those of us not keen on cutting up the bumper? Would they fit?
Finished mine - Took a bit ore time to complete than expected.
Agree that the 8 unit lights fill the space nicely -
While I appreciate the aesthetics of having the bolts placed mid-line with the bracket, moving them outboard just a bit might give us a bit more room to manipulate the drill bit to get things on metal.
Granted these things would stay in tight with just the two larger bolts , but having the rest make it look great... Just a bit unnerving even when you cut on the small side and still have to decide where you will get good drilling surface.
I would also like to see the mounting holes for the LED on the rear of the bracket a few sizes larger. Mine did not fit the LED's and I had to drill them out. Unfortunately I was not thinking and after drilling one size, lifted the bracket off the rag and got shavings under it. Drilled again only to find I scratched the power-coat and had to repaint.
No issue at all and a stupid mistake on my part.
I think this is one of the best looking mods you can do... Love them!
Did you install the Phillips mounting bracket in the housing first? I had no problem with the rear mounting holes. I had to go through my hardware scratch been to get a couple small bolts/nuts/washers but didn't have to drill out anything to mounting the Phillips bracket in the unit. Then the lights just snapped right in.
I have 2 issues with the Philips LED's. My battery keeps draining when I don't drive it for a while. When I plug my battery tender in it turns the lights on. I have to unplug them when I'm not driving it. I know the lights come on when it senses current. Looks like I need to install an on/off switch. Anyone else having this issue?
