My 40 stinks
Discussion in '40- & 55-Series Tech' started by ScottFJ40, Jul 16, 2003.
  1. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    I need an exhaust. Would you all recommend a bolt on from one of the vendors, and if so which one?
    Or would I be better off going to a exhaust shop and have them twist me one up?
    I have a 78 with no cat, and the exhaust runs under the skidplate. I want the new system to run over the skid.
    Thanks in advance.
  2. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    I would take it a competent shop. Tell them exactly what you want in terms of routing. I used a bolt together system on my MG and still ended up having a shop modify it to make it work better.
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    good shop no question.
  4. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    i recommend the manafre kit that is matched with their 6-1 headers. very clean looking. the only thing is that i didnt pay for it, the po did...so i dont know how much it will set you back, but i like it! 8)
  5. ScottFJ40
    ScottFJ40
    536
    Jan 30, 2003
    Thank's guys, a shop it is.
    I'd go your route FatKid, but I have no header. :D
  6. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    I have SOR's clamp on. It works fine, but there are small leaks at the joints. I like the idea of being able to take things apart and move them: came in real handy when I rearranged things for fitting the winch and PTO, and putting it all above the skid plate I aquired. I had the shop weld the one joint at the flange for my MAF Header pipe when I had everything else where I wanted it. Anyone have a reversable way of effectively sealing the small leaks in and out of the muffler?
  7. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    [quote author=ScottFJ40 link=board=1;threadid=3716;start=0#msg27419 date=1058449917]
    [/quote]
    they have a pipe to go from the flange up to the stock manifold... :D
