Teaser shots of what's in the works:
More to follow...
Long travel? Is axle position moved forward to clear larger tire from rubbing body mount?
Interesting, wonder how it will be different than the Total Chaos lower arms. Not sure how they will yield more travel other than positioning the lower coil over mount differently, because the limiting factor on my BP-51s is the BP-51s.Not going to be LT but I am told there will be a increase in travel. No change in axle position.
Yea, but the inner CV angle is getting real sharp. And with a longer extension length you will have a longer compression length, so you would sacrifice uptravel. That's good for rock crawling, but bad for moderate speed overland stuff.If you could get the BP51's with longer shafts, could you get more travel?
Cool, do they have a price out yet? With the total chaos being $2700, maybe these will be obtainable, as long as they use a good bearing. Cool find, I'll be paying attention to this one.These are being designed and built for speed in the sand and dirt as well as overlanding.
No work on my end.Seems like a lot of work
Not everyone can just go get Tundra arms.you can just use the Tundra arms
I'm not concerned. I've beaten the hell out of all my Toyota's, as well as quite a few that weren't mine, and never had an issue.If you are concerned about the durability of the stock components
I'm definitely no trophy truck driver. These will not cost $2700. There's definitely a market for them or Brenthel would not be making them. That market is likely mostly overseas where they run their LC pretty hard and have the $$$ to mod, break, mod, break, etc. This is why they are being made and why the Tundra arms are not readily available as that is a North American based truck.
can you share the amazon link for the front grille order !
Wish it could come with the camera holder. I suck with a dremel.
