Anxiously waiting to see pics from you guys that went with the vinyl. Charcoal/black vinyl for me.
In for a brown vinyl set when available. Thanks J!!
Interested in how the vinyl comes out too... would want to know how any padding underneath would work.
my supplier says you can put up to a 40oz jute padding under the vinyl or carpet.
Those are great news...can't have enough noise/heat barriers on the floor..!!
F,
I switched over to Thermozite and can't say enough good things about it. It is a heat and noise barrier in one. They make it double foil sided as well.
I'm going to say it is in the 28-32oz range but man is it dense.
J
What's your source for Thermozite? Do you use any adhesive to hold it in place?
Jim,
Here is the cheapest (material and shipping combined) I've found. They sell single and double sided foil. Under the carpet I just laid it in, no glue, etc.
I never noticed any shifting of the carpet. I'd say a spray adhesive like a 3M would be your best bet and "easier" to clean up if you ever need to remove the flooring.
Thermozite Insulator Padding - Sound & Heat Solution
This adhesive is what I use for my door panels and heavier duty applications.
3M Spray Adhesive, 17.6-Ounce - Aerosol Adhesives - Amazon.com
Jason
Followed the link and saw a photo of the Thermozite applied as a hood insulator - could that be a good solution for FJ60s/FJ62s?
Did you use single or double sided foil under your carpet?
Next question for under the carpet - foil side up or foil side down?
