A friend of mine purchased a new mill and had it shipped to my shop as he had no way of off loading it. The other factor was that he lives in a gated community with limited access for freight trucks. His drive way is quite steep and his garage header is only 7', so my fork lift would not be of any help.
I decided on a base frame of 3/8" x 4"x4" angle with four cantilever castor plates. The castor plates are 3/8" x 4" CR broken to 22.5º and are welded to a small section of 1/4" x 3" x 3" structural tube at 45º. The same tube was used for leveling brackets cut at a 45º. Leveling feet bushings where turned and index into 11/16" hole and welded.
The machine was uncrated and a cardboard template was made to include the location of the mounting bolts. A large transfer punch was turned on the lathe to mark the hole locations on the frame prior to welding allowing us to drill/tap single pieces instead of man handling a large frame.
The iron worker made short work of the notch required for the corner joints.
I went ahead and made four extra castor plates for my plate roller while I had the break setting on the iron worker. These are broken to 22.5º
Once welded to a small section of 3"x3" tube cut at a 45º the castor plates will be parallel to the floor allowing the castors to swivel 360º.
A shot of the leveling bracket and threaded bushing.
reached my limit of photos for this post. continued...
