Correct.BTW, we are talking about the solenoid portion of the starter when we are talking "starter", correct? That is what I was testing... power bolt on solenoid and touching body of solenoid.. correct?
There were several things that it could have been until you eliminated them. Battery, cable insulation, one of the other wires connected to the battery...
It sounds to me like the story is that your starter developed a short that wiped out your battery. When you tried to jump it, the short showed up as the sparking/melting jumper cables.
What I am unclear on is why the starter developed this short. We'll probably never know unless you take apart the solenoid before you take it back. Also, how did the original starter fail and could this be related?
If Costco does not replace your battery, you should consider getting a charger and try to revive the battery. It's a good thing to have anyway.
Finally, I'm not a mechanic (just an electrical engineer that has owned a lot of old cars) so I could be missing something here. My advice is worth what you paid for it.
Luck.
yep, bought at Costco 1 month shy of 3 years just under the full warranty wire. they say they still have them, so was thinking of getting the same.
OR, should I take the money and run and get something else?
When you say that the starter passed tests 100%, was one of the tests measuring the resistance from the solenoid terminal to the case? You did this test and it failed. Now it passes?
does any of this shed light on the issue? Could it be the alternator?
