Max-Trax Substitute?
Discussion in 'Winching and Recovery' started by BJTLC100, Jan 16, 2012.
  1. BJTLC100
    BJTLC100
    455
    74
    Jun 28, 2010
    Centennial, CO
    I was wondering what people's thoughts were if I might be able to recycle an old plastic pallet, trim off the feet, cut it into half and use them as sand ladders/traction ladders. What do you think?
    [​IMG]
    I found some here in Denver that are only $25 a piece.
  2. Devilmans Hand
    Devilmans Hand TLCA #19517 SILVER Star
    3,151
    Media:
    21
    184
    Aug 4, 2008
    Commonwealth of N.VA
    I've been thinking about the same thing. Test them out and report back.
    I think they'll work, but not as well as a purpose built product
  3. cody c
    cody c
    4,632
    20
    Feb 20, 2006
    calgary
    I thnk the max trax have a better friction surface on top than the pallets, these might be slick with muddy tires.
    Having said that I think the price of the maxtrax are a bit inflated, if I had access to some free pallets Id probably give them a try myself.
    Also, I suspect one of the key features to the maxtrax is there length, which distributes the weight of the tire better to get above the sand/mud/etc.
    Pallets might be not as effective for that reason.
  4. BJTLC100
    BJTLC100
    455
    74
    Jun 28, 2010
    Centennial, CO
    I agree with the comments on the Maxtrax. Very good point about the pallets being slick if they are wet or muddy. The size of the Maxtrax are: 115 cm (3.77') long, 33 cm (13") wide and 7cm (2.75") high. Two stacked MAXTRAX are just 8.5 cm (3.3") high, 4 are 115mm high.
    The pallets are 40"x 48" by 6", so I would cut them in half thickness wise, and then down to 13" or 14" width wise and be set.
    What do you think if I would wrap some of the splines with skateboard tape for added friction? Do you think that might be enough for better traction?
    What do you think the best saw or blade I should use to cut these thick plastic pallets?
  5. e9999
    e9999 You want to do what...? Moderator
    16,188
    301
    Sep 21, 2003
    PRK
    I would not fool around with the thickness. Would be hard to cut and the thicker the stronger. You could cut in some grooves with a router for better traction.
  6. cody c
    cody c
    4,632
    20
    Feb 20, 2006
    calgary
    actually, used snowmobile track on a rigid surface would be excellent. Might be able to pick up some older used tracks for free depending on what area you are in.
    Maybe attached to something like an old aluminum ladder or something. That might even work better.
  7. BJTLC100
    BJTLC100
    455
    74
    Jun 28, 2010
    Centennial, CO
    Has anyone used old tires cut open to lay flat? I thought I saw that posted somewhere?? Would those work very well?
  8. Devilmans Hand
    3,151
    Media:
    21
    184
    Aug 4, 2008
    i've seen some military folk use cut up aggressive tread tires before.
    sometimes it is nice to have something rigid to bridge with though. I just carry a couple 1" thick boards. too big though to just leave in the vehicle.
  9. Woodsman
    Woodsman
    108
    Jan 10, 2011
    Batesville, IN
  10. Devilmans Hand
    3,151
    Media:
    21
    184
    Aug 4, 2008
  11. madinal
    madinal
    254
    Sep 4, 2009
    Madison Alabama
    I have been looking for one of those old rubber entrance mats, the kind that is built with rubber rectangles and wire. I figure they can be cut down to 48 x 15. They can be rolled up and stored and not take up much room.
  12. e9999
    16,188
    301
    Sep 21, 2003
    PRK
    man, these things look like they'll do a nasty number on your tires, with all these spikes
  13. Woodsman
    Woodsman
    108
    Jan 10, 2011
    Batesville, IN
  14. IBCRUSN
    IBCRUSN
    2,173
    Media:
    7
    2
    Sep 13, 2003
    Wichita, KS
    The pallets might work well if you flip them over and put the smooth side down. Aren't maxxtrax more for distributing the weight of the vehicle in soft sand, mud, etc? If they get wet they won't have any better traction.
    If something to disperse the weight of a vehicle try poultry flooring, same waffle type pattern and close enough to disperse weight and not sink and ~$21 for a 2'x4' piece. Cut one in half and you have two. They won't be strong enough to bridge with but they will be a bit flexible to conform to the terrain.
    PolyMax Poultry/Kennel Flooring - FarmTek
  15. Tahomatom
    Tahomatom
    181
    Media:
    5
    May 25, 2010
    SF Bay
    You should be able to find some of those pallets in any industrial park. They break all the time so we they tend to pile up in the back of warehouses.
    Drive by a local freight company. Many customers want their pallets to look perfect at time of delivery so they just switch them out before delivering.
  16. yoopercharged
    yoopercharged
    1,132
    Media:
    3
    3
    Apr 17, 2009
    Marquette,MI
  17. boodzman
    boodzman
    11
    Feb 12, 2012
    Australia, Wollongong
    there is a guy on lcool forum that is trying milk crate bases joined together. they could be picked up for free too
  18. AutoCraft Aus
    AutoCraft Aus Araco Master
    587
    282
    May 21, 2008
    Between the bay and the Ocean Vic Aus.
    The smitty built ones are about the same price as the maxtrax knock offs over here.
    Cheaper way would be buy a pr and go halves with someone, because right tyres, right pressures, makes one maxtrax about as useful as 2.
    We have a theory on those who carry maxtrax here..........:doh:
  19. BirfMark
    BirfMark
    453
    3
    Apr 15, 2009
    Ft. Collins, Colorado
    You could easily weave/tie a bunch of large diameter rope through the pallet openings in order to increase the traction.
  20. mickeyt
    mickeyt
    2,258
    9
    Mar 2, 2011
    Providence Rhode Island
