- Thread starter
- #61
My rear end will drop 8". The front of that bar needs to drop straight down about 4" for it not to bind in this situation. With that fixed front end it will only allow the rear to drop about half the distance and then it will hold the rear up. You would not be able to remove the bolts. I call that bound up.
That's not to say it won't work on the trail, but it will put stress on the bar and it's mounts and may eventually lead to it breaking.
That design makes the classic mistake that putting the front pivot at the spring pivot solves all the problems. The flaw is that the spring is flexing and the bar is not. Here's a quick picture showing the spring flexed (bottom) and not flexed (top). The perches and spring plates remain relatively flat on downtravel. Don't take my word for it. Try it.
