Man-A-FRE Part time 4x4
Discussion in '80-Series Tech' started by yomama, Apr 4, 2003.
  1. yomama
    yomama
    291
    Mar 27, 2003
    Have any of you noticed the part time 4x4 mod on their website?
    I had talked to the owner sometime back and he was going to install it on his cruiser, I never heard back from him whether or not he did it. I have read though that in order to use it you have to keep your center diff locked, don't know if I would care for that, however the additional power and fuel mileage might not be bad.
    Yomama
  2. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Yomama, the conversion puts AVM hubs on the front axle, with 4wd high operated by the center diff lock switch once the hubs are manually locked. Slight T-Case mods are necessary. Christo has a write up on his technical page. I don't know exactly how much difference in gas mileage you get, but the last person I know who had the conversion was still looking into putting a 350 chev. in his crusier....FWIW.
    -H-
  3. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    O' I looked at it to deal with a front driveline vibe that I have always had and can't seem to get rid of.... :-/
    -H-
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,564
    2,891
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Yo,
     It could get wierd trying that with a HF2AV transfer, as the coupler is in there in order for the ABS to work correctly. I believe that the PT conversion detailed on Christo's site was for a HF2A, like what -H- has..........
      Regerds......Dan :beer:
  5. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    Yup, correct as usual, 1991-1992 models only. :tear:
    -H-
  6. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    So this kit won't work for a 96?
  7. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Not if you've got ABS (rear discs).
  8. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    think the write up on Slee said they gained about 3 miles a gallon, which doesnt seem like it would make it worthwile in itself. sounded like power improved slightly.
  9. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    When my Viscous Coupler went bad, I removed the front drive shaft and locked the center diff. Locking the center diff shouldn't be a problem as long as you the hubs are unlocked. When the CD is locked the VC not in use. The front and rear of the VC can't spin at different speeds. I could of just removed the VC and disabled the antilock brakes. But if one wheel lost traction I would be stuck. The VC is there to lock up the shafts when one shaft spins more than the other. I wanted to keep the antilock brakes so I got a new t-case. If you add lockout hubs you will lose the antilock brakes when you have the hubs unlocked. I see no advantage to having lockouts as the front drive line will still all be moving at the same speed locked or unlocked. Unlocking wont get rid of the front drive shaft as it will still be spining.
    kurt
  10. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    As I understand the VC, if you put hubs on a 93+ the VC will just put more power to the front, (ie. open differential) and not provide enough power to the rear unless the center diff switch (if equipped) is locked.
    Correct me if I'm wrong. :stupid: :slap:
    -H-
  11. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    You can drive with the front hubs unlocked but it will slip as the VC is trying to send power to rear. When it gets hot enough it will lock solid. I wouldn't run that way as it might ware out the VC. When my VC got hot, it took 3+hrs to cool and unlock. It would of took longer as took a hose to it after the 3rd hr.
    kurt
  12. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
    :-X Be really leery of anything M-A-F says- from my experience!!!! :ugh:
  13. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    The actual kit is from Mark's 4wd Adapters out of Australia, just sold by MAF.
    -H-
    (Almost a "Junior") :D
