Make a pitman arm?
Discussion in '40- & 55-Series Tech' started by 78goode40, Mar 18, 2003.
  1. 78goode40
    78goode40
    6
    Dec 24, 2002
    Is there somewhere I could get a pitman arm manufactured?
    I need a stock arm, cause of stock relay rod, but I have a hi-steer setup with GM 1ton rod ends.
    Can anyone advise?
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    You can have the TRE reamed to the correct size and taper and I have heard of having the splines drilled out and the splines from another arm welded in, but having a whole manufactured from scratch, I have not seen. If it was flat I suppose it wouldn't too difficult.
  3. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Making a new Pitman arm would be about the most difficult solution to this dilemma I could think of, and would still not solve the problem. Your problem is NOT the Pitman arm, but the drag link, or relay rod as you call it. If your hi-steer uses 1-ton tie rod ends (TRE), they will either have 7/8 or 1" threads -- way larger than could ever be mated to your OEM drag link. You need to have someone make you a new drag link that is large enough for 1-ton TREs (I use 1.375" o.d. DOM with a .375" wall). You can then either ream out the Pitman arm to fit a 1-ton TRE, or use a smaller TRE on that end -- like one that already fits the Pitman arm. Often on these custom steering setups you have to spend some time coming up with the right TRE for the particular configuration.
  4. 78goode40
    78goode40
    6
    Dec 24, 2002
    I have already tried reaming out the pitman arm. But of course, there was maybe a 1/16" of an inch around the outside of the hole, so I did not even try to put it back on and drive it.
    I guess a new PS setup would allow for a pit arm that will accept 1ton TRE and get rid of relay rod. I currently have the toyota setup, but I still have the factory relay rod running down the inside of driver's side fender, stock pitman arm, etc.
    Should I go saginaw and do away with toyota?
  5. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Throw the Toyota steering stuff away and install a Saginaw (GM or Scout) power steering system.
  6. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    second the Scout or GM saginaw option....major improvement when you are running larger tires (35" and over)
