Firstly, how the heck do you get these two parts separated? We have tried everything from gently tapping with a hammer to trying to dissolve the seal with acetone. There is nothing but a rubber seal holding them together. I cannot get a screwdriver in between the two parts to pry them. We even warmed it up to about 100 degrees fahrenheit.
Secondly, on most of the M12000 diagrams the "top" of the motor is supposed to come out of the housing. Pretty sure ours does not. Am I wrong?
We had to ram the brake out of the drum relatively violently. It simply would not come unstuck, period, so we put a wooden dowel in there and slammed the entire drum down on it repeatedly until the brake assembly came out. We will probably need a new one.
We took down the motor. Is that gum supposed to be there?
Finally, just for fun, be careful using impact tools on the solenoid terminal. Oops. New solenoids it is...
