Ha-yes... With car stoppedWith car stopped
No, not on the whole time... Loooong story but it is my exes truck. I "thought" he had installed a switch at one time, asked, and was just told to drive in circles and it would go off... No confirmation that the switch had been installed/broken until today....so, with that being said, hopefully it will be an easy fix ... I appreciate all of your responses.Man Inkpot. You're good. Answering before you were summoned
Good start. It would be located here and other Toyota switches may work in its place. Commonly another hazard switch is used. Here's it's locale. Maybe hit a junkyard up and save a few bucks
Has it been on the whole time you've owned ?
Or unhook the current hazard, hook up to diff lock, press to disengage?Another maybe dumb question. Can I trace the wire back from the broken switch and just unhook it for the time being? I've located that wire. I'm guessing that would not disengage but just leave the situation the same?
yes, way to think outside the box. Then buyva used hazard switch for like $15 on eBay and put it in the hazard spot. You will have ground the plastic tab down on your current one to make it a cdl switch. Do a search for hazard cdl switch if you aren't sure what to grind.Or unhook the current hazard, hook up to diff lock, press to disengage?
