SOLD LX-450 Super Charged, Locked, Lifted (1 Viewer)
SOLD!
Selling my LX450 I was building for an overland rig but have changed plans for
what I want to use for overlanding and this is the reason I'm selling this build.
It has been deflared and from the bottom window line down resprayed. Interior
is in great condition and yes both seats work.
All work listed below was recently done and has less than 50 miles of service.
1997 LEXUS LX450, TRD Supercharged and TRIPLE LOCKED
VIN: JT6HJ88JXV0167430
• 188,425 miles(updated 10/05/2017)
• All main coolant lines replaced
• New Coolant and New OEM thermostat
• New OEM Cap, Rotor, Wires
• New Plugs
• All New Belts
• New Front Main Seal
• New Oil Pump Seal
• New Valve Cover Gasket
• New OEM Oil Filter and AMSOIL
• TRD Supercharger(this unit and all proper parts were sourced used with only 10K miles on the SC)
• OME Steering Dampener
• Iron Man 5” Lift with foam shocks
• ARB Front and Rear Adjustable Panhard Rods
• New DBL Cardin Front Drive Shaft
• Aluminum bump stop blocks on all four corners
• Front Sway bar drop blocks, 2” aluminum
• Rear Sway bar drop brackets
• Stainless Extended Brake lines
• Diff breather hose extensions
• Center Diff Lock
• 7-pin mod
• Breather Snorkel
• All New Crossed Drilled and Slotted Rotors/Pads
• Front & Rear axle fresh fluids
• Brand New 315/75/16 TOYO Open Country (x5)
• LED dome and door lights
• New ARB Front Winch Ready Bumper
• New Custom(fabricator Sean Huston) Rear DBL Swing Out Bumper W/Ladder Basket
• New Melvill and Moon Front Seat Covers – these covers are from South Africa and not
available in the US.(drivers seat has small tear nothing major not all ragged out, passenger seat has no tears and is in good condiditon) Seats are fully functional.
• New Escape Gear Dash Pad Cover with pockets – this is a really cool dash pad.
This rig is back on the market. Couple of changes made to it are:
1. Replaced the center shift console out.
2. Replaced the center arm rest console to a LC80 style.
Photos to come soon.
I'm sure that I'm forgetting other work done and will update posting as needed.
Yes, I have rear jump seats.
I'm located in Spicewood, TX about 25 miles West of Austin, TX.
If you have any further questions, I'll be happy to answer them.
I can be reached at 512-800-8869 - call or text.
Thanks
Archie
Oh man, this is one of the cleanest 80's I've seen here in a while.. GLWS
How'd you like the Ironman lift? Considering on getting a 4 inch for my LX.
let it go flagged, a real cruiser guy will buy it from this site anyways.
GLWS, she's a beaut!
I'm in the Austin area and am interested in this truck. Have you addressed the cooling problems inherent with the SC setup?
Gandy,
Has not shown any cooling issues and that was mainly on the 93/94 with smaller injectors. Call me if you care to discuss. 512-800-8869.
Archie
The guy flagging them Might be the dude spamming the fj80 ads all over texas located in the river oaks area -houston. He posts 3 new ads a day iIthink hhe's a land cruiser flipper
I'm in the Austin, TX area and some JACKASS keeps flagging my local Craigs List add!!!
Craigslist also has automated systems that will flag postings. I've found this is especially true of keyword-laden postings. If it seems like your posting has been flagged rather quickly (before it's even up and viewable by others or yourself), then it is likely the automated system at work. I've not found a way around this other than stripping the ad of the detailed info that is causing the problems.
Man, I wish this was within my budget. Very nicely put together LX.
