Lubes for Odometer and Speedometer Cable?
Discussion in '40- & 55-Series Tech' started by PabloCruise, Nov 16, 2008.
  1. PabloCruise
    PabloCruise SILVER Star
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    I have read up on the odometer fix threads and feel like I can fix my odometer in my '74 FJ55
    What I am wondering is what have people found to be the best lube for lubing the odometer when re-assembling? I heard CLP mentioned, but not sure if that is the best bet?
    Also, whil I have the cluster out I thought it would makes sense to disconnect the speedometer cable at the tranny, douche the cable with brake clean, and then re-lube.
    What would the best lube be for speedo cable?
    TIA,
  2. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    Bump for the weekday crew...
  3. Coolerman
    Coolerman
    5,408
    276
    Jan 5, 2004
    Paint Lick, KY
    Some links I found...
    AutoZone.com | Repair Info | Product Information - Speedometer Cable
    Slipkote Specialty Lubricants SLIPKOTE SPEEDOMETER GREASE is a premium quality, low temperature calcium grease that provides superior flexible cable housing lubrication at temperatures as low as -65°F. It is designed to prevent pulsating in wet or dry conditions and will outperform an ordinary grease as a speedometer cable lubricant in Automotive, Truck, Farm, Marine, and Industrial applications.
    https://www.paddockparts.com/Paddoc...sion&mscssid=000755FF4A281634653B3C4B6A3CD081
  4. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    8,711
    482
    Sep 26, 2003
    Lancaster, Ohio, USA
    Nothing. The downward pointed speedo drive gear naturally seeps oil into the cable. Adding other lube just makes it stickier inside.
  5. Coolerman
    Coolerman
    5,408
    276
    Jan 5, 2004
    Paint Lick, KY
    So why does the t-case end of the cable have an o-ring and a felt pad? I thought they were there to keep oil out of the cable? :confused:
    I just remembered I have a brand new cable in a box, I'll check it later to see if it came pre-lubed from the maker.
  6. FJ40Jim
    8,711
    482
    Sep 26, 2003
    They are there to seal the cable. They don't work.
    Or maybe they are designed (especially the oily felt) to seep just enough oil to keep the cable from rusting.
  7. andrewfarmer
    andrewfarmer
    799
    Jul 18, 2005
    Wellington, NZ
    Anything light - white grease works as does engine oil.
    Pull the inner, lube it, wipe it almost all off so there's only a very thin film left and you're done.
  8. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    You mean the speedo drive gear from the t-case?
    Will the rotation of the cable move gear oil up the entire cable, and then seep down when cable is not spinning?
    What about the odometer shaft and gears? What is best lube for that?
  9. ohrly?
    ohrly?
    398
    Nov 4, 2007
    If my speedo needle is bouncing, can I just spray the shit out of the gears with fluid film?
  10. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    I believe speedo needle has to do with cable, the gears in the cluster have to do with odometer
  11. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    Any comments about lube for the odometer cluster?
    I plan on pulling mine apart this weekend. May just use CLP if no one else has anything specific.
    Oil for clippers?
  12. FJ40Jim
    8,711
    482
    Sep 26, 2003
    No specific suggestion.
    Look for a light grease that is very stable and won't dry out & turn into tar after a few years.
  13. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
    Thanks, I am going to try CLP. I guess that is a brand, I will try the Remington equivalent available to me locally. If you look at the marketing to gun owners, it looks like it might be ideal for odometers - long lasting synthetic, low attractiveness for dust.
    I will post up my findings...
  14. Blue77FJ40
    Blue77FJ40 SILVER Star
    2,243
    31
    Nov 30, 2004
    MD
    A light grease you could use for the odo cluster is bicycle bearing grease. Comes in a tube.
  15. PabloCruise
    14,219
    473
    Jun 3, 2004
    Northern Colorado
  16. Matt16
    Matt16
    286
    Mar 22, 2008
    North Vancouver
    I used graphite on my 4Runner speedo cable. it lasted a month or ~1000km, which ever came first. I concluded graphite doesn't work.
    I tried chain lube (motorcyles I guess) and its been 8 months, through a cold winter and no noise or funny needle movements.
Share This Page
