None of the FSMs I have from the usual suspects show anything on the wiring diagrams for the USA electronic ignition, they all show a points dissy. Anyone have the right one? I'd love to have a schematic that was correct for my 1987.
In my 1987 FJ60, there are 3 connectors with one wire each from the harness by the coil:
1. One wire is Black/yellow stripe and is not connected. It has a plug on the end, but there's nothing nearby to plug it into. ??
2. One wire is Black/red stripe and connects directly to the ignition module yellow wire via a connector. I suspect this is the tach signal to AC amp, Emission computer, and tachometer.
3. One wire is gray or green maybe and goes directly to the (+) terminal or the coil. I presume this is switched hot from the key in run position (need to confirm).
Note: the stock dissy is connected directly to the ignitor via two wires from the ignitor module. The only connections to the truck from the ignition gear is #2 and #3. Not sure what #1 is for, and why it isn't connected.
