I ordered a custom longfield axle shaft and flange for my 97 fj80 rear axle that I shortened and put under my 78' HJ40 (2H diesel swap). It has the long spline for the elocker.
My main question is this: What do you do about the axle shaft seal?
The custom shaft is one diameter the whole way roughly 32mm. The seal surface on the original axle is 35mm and therefore the new seals I have are not even close to touching the shaft.
I'm not too happy because I provided them with a proper drawing identifying the length and seal surface required (which was present on a front shaft I bought years ago). Also I expected the flange to be press on the spines at the outer end based on phone conversation a few years ago with the late Bobby Long. Also the little circlip they provide to keep the flange in place is a lot smaller than the machined groove so it is really loose. And one more thing, it is about 1/4" longer than my drawing. If not for the extra spline length I requested it would not have fit. Now I will have to cut 1/4" off the inner end with a zip disk.
Guidance and sanity check needed!
Chris
Chris
