For Sale Locked and Built 96 80 Series Northern CO (2 Viewers)
SOLD, thanks BVCOTaco!
1996 Toyota Land Cruiser
228xxx Miles
Front and rear axle E-lockers
Center differential lock with pin-7 mod
3rd row seats (fully removed but all hardware included)
Port of entry installed Rostra alarm/keyless entry
Optional dash mounted cup holder
The good: No major problems to speak of. I have been driving this truck nearly every day since receipt of ownership in 2010 and it has been nothing but reliable and an outstanding vehicle. The interior is fairly clean given the age and has been non-smoker vehicle.
The bad: it's dented, dinged, scratched, and used like it should be. Mechanically it has some minor issues that will need to be addressed like the front crank seal/oil pump o-ring leak, rear main or possibly pan leak, and LSPV leak (slight leak when fully flexed). It throws a P0420 code every once in a while due to the high flow/low profile cats and will not pass CO emissions standards with the current cats according to the emissions facility as they are not efficient enough. Some blue smoke is noted on startup and is a common occurrence with these trucks. Interior wear items are typical for this truck such as slow windows, driver side seat that doesn't move ( Gamiviti gears included), cracked leather, some small tears here and there, glove box door that flops open, etc etc.
History: Purchased from a fellow Land Cruiser enthusiast bone stock and was a Colorado truck previously.
I am offering this truck for sale to move up to a GX470 or 100 series. My family has evolved and we simply don't go wheeling like we used to, I have also acquired a 40 series that will be the play truck from here on out. I am sure I am forgetting some things but the bulk of it is listed. As the weather improves I will be working on some of the items that need addressed and will update the thread as it happens. Located in Fort Collins, CO
Modifications:
Hawk Industries rear bumper with built in receiver hitch and swingout using an IPOR spindle and Destaco latch
Hawk Industries front tube bumper
OME Nitrocharger shocks
OME Medium Rear Springs
Ironman 2” front springs
MAF control arm drop brackets
Slee extended chassis brake lines and rear caliper lines
OME steering stabilizer
Front swaybar disconnect brackets
Landtank Gen3 Maf
High flow, low profile Magnaflow catalytic converters (will not pass CO emissions requirements)
A/C drier relocated to 91/92 model year position
Weathertech rear cargo liner
Husky front floor mats
Exact fit front seat covers
Alpine head unit and Pioneer speakers
Uniden 510xl CB mounted in ashtray location with bumper mounted Wilson antenna
Heavy duty d-rings mounted in trunk floor for securing a fridge
Marinco 12volt rear socket wired with 8 gauge wire for fridge use
LED interior lighting
Front windows tinted with a close match to the factory tint
Slee speedo gear for 33” tires
JDM rear license plate bracket
Tray for a second battery is included but not installed
285/75R16 Duratrac tires with half or more tread, one extra tire included (6 total)
Deflared and plasti-dipped, original flares are included and can be reinstalled.
Mx that has been performed during the duration of ownership since 2010/185k:
Front u-joints replaced with OEM Toyota parts
Rear axle bearings repacked, rear rotors replaced and pads replaced with Aekebono ceramic pads
Front axle service, new wheel bearings, new brake rotors, and Aekebono ceramic front brake pads
Brake fluid flush with ATE Super Blue
Transmission fluid flush
Denso spark plugs
Cap, rotor, and plug wires replaced
PHH bypass with Gates hose
P0401 fixed by cleaning carbon from intake manifold ports and replacing numerous vacuum lines
EGR modulator replaced with OEM Toyota part
TPS sensor replaced with OEM Toyota part
Front and Rear O2 sensors replaced with Denso parts
Coolant flush and radiator hoses replaced
OEM Toyota oil filters always used
Differential fluids changed with Subaru Extra-S synthetic
Fan clutch fluid replaced with higher viscosity fluid
A/C recharged along with A/C drier relocation
Charcoal canister replaced
Gas cap replaced
PCV valve replaced
Fuel filter replaced
Vacuum lines replaced
Rear hatch lock actuator replaced
Rear hatch struts replaced
Windshield recently replaced with a new gasket
I am sure there are items I am forgetting to list
PM'd
Looks like I am going to be the proud owner of this 80 series on Sunday! Thanks kbahus!
