  2. Classifieds Guidelines...
    • - Prices: POSTING PRICES is a courtesy, PLEASE include. NO biding or best offers, this is not EBay. NO prices in Title.
    • - Location: IH8MUD reaches over 200 unique countries. Include your state/country in the Title.
    • - Sold Items: Threads remain for price/product research. Make a final Reply to note your item is sold.
    Tie Rod Media LLC does not get involved in transactions or disputes. PLEASE perform your own due diligence to ensure a smooth transaction.
For Sale: Locked and Built 96 80 Series Northern CO
Discussion in 'FJ80 | FZJ80 | LX450 | HDJ81' started by kbahus, Feb 25, 2014.
  1. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    SOLD, thanks BVCOTaco!
    1996 Toyota Land Cruiser
    228xxx Miles
    Front and rear axle E-lockers
    Center differential lock with pin-7 mod
    3rd row seats (fully removed but all hardware included)
    Port of entry installed Rostra alarm/keyless entry
    Optional dash mounted cup holder
    The good: No major problems to speak of. I have been driving this truck nearly every day since receipt of ownership in 2010 and it has been nothing but reliable and an outstanding vehicle. The interior is fairly clean given the age and has been non-smoker vehicle.
    The bad: it's dented, dinged, scratched, and used like it should be. Mechanically it has some minor issues that will need to be addressed like the front crank seal/oil pump o-ring leak, rear main or possibly pan leak, and LSPV leak (slight leak when fully flexed). It throws a P0420 code every once in a while due to the high flow/low profile cats and will not pass CO emissions standards with the current cats according to the emissions facility as they are not efficient enough. Some blue smoke is noted on startup and is a common occurrence with these trucks. Interior wear items are typical for this truck such as slow windows, driver side seat that doesn't move ( Gamiviti gears included), cracked leather, some small tears here and there, glove box door that flops open, etc etc.
    History: Purchased from a fellow Land Cruiser enthusiast bone stock and was a Colorado truck previously.
    I am offering this truck for sale to move up to a GX470 or 100 series. My family has evolved and we simply don't go wheeling like we used to, I have also acquired a 40 series that will be the play truck from here on out. I am sure I am forgetting some things but the bulk of it is listed. As the weather improves I will be working on some of the items that need addressed and will update the thread as it happens. Located in Fort Collins, CO
    Modifications:
    Hawk Industries rear bumper with built in receiver hitch and swingout using an IPOR spindle and Destaco latch
    Hawk Industries front tube bumper
    OME Nitrocharger shocks
    OME Medium Rear Springs
    Ironman 2” front springs
    MAF control arm drop brackets
    Slee extended chassis brake lines and rear caliper lines
    OME steering stabilizer
    Front swaybar disconnect brackets
    Landtank Gen3 Maf
    High flow, low profile Magnaflow catalytic converters (will not pass CO emissions requirements)
    A/C drier relocated to 91/92 model year position
    Weathertech rear cargo liner
    Husky front floor mats
    Exact fit front seat covers
    Alpine head unit and Pioneer speakers
    Uniden 510xl CB mounted in ashtray location with bumper mounted Wilson antenna
    Heavy duty d-rings mounted in trunk floor for securing a fridge
    Marinco 12volt rear socket wired with 8 gauge wire for fridge use
    LED interior lighting
    Front windows tinted with a close match to the factory tint
    Slee speedo gear for 33” tires
    JDM rear license plate bracket
    Tray for a second battery is included but not installed
    285/75R16 Duratrac tires with half or more tread, one extra tire included (6 total)
    Deflared and plasti-dipped, original flares are included and can be reinstalled.
    Mx that has been performed during the duration of ownership since 2010/185k:
    Front u-joints replaced with OEM Toyota parts
    Rear axle bearings repacked, rear rotors replaced and pads replaced with Aekebono ceramic pads
    Front axle service, new wheel bearings, new brake rotors, and Aekebono ceramic front brake pads
    Brake fluid flush with ATE Super Blue
    Transmission fluid flush
    Denso spark plugs
    Cap, rotor, and plug wires replaced
    PHH bypass with Gates hose
    P0401 fixed by cleaning carbon from intake manifold ports and replacing numerous vacuum lines
    EGR modulator replaced with OEM Toyota part
    TPS sensor replaced with OEM Toyota part
    Front and Rear O2 sensors replaced with Denso parts
    Coolant flush and radiator hoses replaced
    OEM Toyota oil filters always used
    Differential fluids changed with Subaru Extra-S synthetic
    Fan clutch fluid replaced with higher viscosity fluid
    A/C recharged along with A/C drier relocation
    Charcoal canister replaced
    Gas cap replaced
    PCV valve replaced
    Fuel filter replaced
    Vacuum lines replaced
    Rear hatch lock actuator replaced
    Rear hatch struts replaced
    Windshield recently replaced with a new gasket
    I am sure there are items I am forgetting to list
    [​IMG]
  2. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    20140610_151752.jpg 20140610_144302.jpg Bump for an update:
    Front crank and oil pump seals replaced
    New Cooper ST/Maxx tires
    Cooling system overhaul with Koyo radiator, Aisin water pump, and Aisin blue hub fan clutch
    Tekonsha brake controller
    Alignment checked
    OME medium rear springs installed
    New price of $8500
    Will trade for a 100 series.....
  3. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    bump, open to offers
  4. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Is the market going soft on 80's or is the price too high?
  5. Sam Stewart
    Sam Stewart No longer kicking boxes... Supporting Vendor Moderator
    3,900
    336
    Sep 30, 2011
    Atlanta
    Really nice truck but I think you're priced a little high. Also, not being able to pass emissions is going to be an issue for a lot of people.
    FWIW, the prices seem to be dropping on the 80s and 100s considerably lately. You're in the 100 price range right now. Most of the 80s I have seen are around the 5-6k mark even with some substantial mods.
    Edit: 100 Series for $8000...
    http://forum.ih8mud.com/threads/1998-100-series-ky.812818/
  6. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Yeah I probably should clarify on the emissions, since "Clean Air Colorado" took over emissions (we wen't without emissions for quite a while) they put such strict requirements on vehicles that many people have a hard time passing. My truck just barely wouldn't meet their required numbers for the production year. It's really insane, the numbers my 96 is supposed to meet are far more stringent than anything around in 1996 when the truck was designed. I would venture to guess this vehicle will pass emissions in probably any other state aside from California and Colorado.
    Here are a bunch of pictures I uploaded this morning:
    http://s1355.photobucket.com/user/kbahus/slideshow/1996 Land Cruiser
  7. Sam Stewart
    3,900
    336
    Sep 30, 2011
    Atlanta
    Atlanta is the same way. If it has a CEL or stored code from a previous CEL it's automatic fail. They also measure the tailpipe emissions depending on year. It would most likely need a cat to pass here.
  8. Sam Stewart
    3,900
    336
    Sep 30, 2011
    Atlanta
    Checked out the other pics. Looks like a pretty nice truck. GLWS.
  9. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Do the do the rolling road dyno test in Atlanta? Thanks for the compliments on the truck too!
  10. Sam Stewart
    3,900
    336
    Sep 30, 2011
    Atlanta
    I know they used to. Been a while since I had to do one like that. All of our vehicles lately have been too old or too new to have to do that test! 96 and up (OBD2) is auto fail for the CEL and I think no sniffer. Pre-96 is NOT auto fail for CEL (I think...) and they do use the sniffer. I haven't seen any of those rolling dyno testers in a long time so I guess they don't do those anymore.
  11. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Price drop to $8000, I don't think I will go any lower.
    I found the emissions paperwork, it blew a 5 on Nox on the dyno and max is 3.5, it is not too far off.
  12. axel52
    axel52
    13
    Jul 13, 2014
    Bend Oregon
    sent you a pm-thanks
  13. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Just found that we will be moving to Michigan in October, I will drop the price to $7500 if it sells before I move and that is the bottom line.
  14. BVCOTaco
    BVCOTaco
    83
    27
    Aug 14, 2014
    Buena Vista, CO
    If I could sell my 02 Tacoma, i would be all over this thing! GLWS. If you still have it in a few weeks, I will contact you.
  15. 4rings5cyls
    4rings5cyls
    35
    6
    Aug 31, 2014
    Westminster, CO
    Just sent you an email from you CL posting.
  16. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Someone please buy this truck before I move, $7000 will get you the title for a limited time.
  17. shawner2713
    shawner2713
    42
    Aug 25, 2011
    My built 03' v8 4runner is kind of like a 100 series...
  18. kbahus
    kbahus SILVER Star
    1,576
    108
    Jun 13, 2010
    SW Michigan
    Feel free to pm me details and a location.
  19. WarWagon
    WarWagon '97 LX450 Locked
    885
    70
    Dec 9, 2013
    North GA
    Love this truck.....someone buy it!
  20. BVCOTaco
    BVCOTaco
    83
    27
    Aug 14, 2014
    Buena Vista, CO
