Awl_TEQ
Supporting Vendor
@Dougal , @gerg , @yotahed
What do you guys think?
I am concerned about an exhaust leak apparently coming from between the Hot side and the center section of my turbo. I wiped off the soot seen on the charge side the other day and it came back right away. I am down 5psi on boost without any change to fuel. This is likely why. And how do I remedy the situation? Can I laser cut a thin (0.010"-0.040") stainless washer/gasket and install it in the shoulder recess where they joint together.
the bolts are tight and the assembly is snug
disregard the oil weeping from the drain
