Knuckle Rebuild Questions
Discussion in '40- & 55-Series Tech' started by Trevor, May 23, 2003.
  1. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    I'm going to spend this weekend rebuilding the front end on my 77 FJ40. Therefore, I'm going to use this thread for any problems that I run into. So...
    Problem #1: How the heck do I separate the birfield from the inner axle? I have seen Mark Whatley's method with the Schedule 40 pipe, but it's not working for me. Should I just keep dropping it? How many drops will it take? It's starting to curve the end of the pipe in around the axle. Has anyone else had this problem? I'm glad I'm not on the trail repairing this, I'd be SOL!
  2. SpaceGhost
    SpaceGhost
    467
    1
    Feb 1, 2002
    Indianapolis, Indiana
    Are you dropping the axle assembly into the pipe? That won't work. Get some gloves, slide the axle into the pipe. Hold the birf stub with your strong hand and the pipe with the other. Raise as hi over your head as possible and slam the pipe to the ground. I suggest at least a piece of plywood protecting a hard surface, like driveway or garage floor.
    Once you do it hard enough it will seperate! The pipe deforms before the inner cage/race so don't fret.
  3. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    Cool. I'll give it a try in the morning. I had to stop because the neighbors were complaining about the noise. :p I forgot that I was working on a Land Crusier. I was being gentle with it, as if it were a Jeep axle... :G
  4. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    Thanks SpaceGhost, it worked.
    Question #2: I'm putting everything back together now. How much wheel bearing preload should there be, according to the fish scale method?
  5. darkman
    darkman
    91
    1
    Jul 22, 2002
    Trevor:
    A right angle pull of 3.9 to 5 lbs is correct to move the steering knuckle assembly in either direction. This pull should be done from the knuckle arm.
    I think that's what your looking for
    Mike
  6. Ky_-_Hoosier
    Ky_-_Hoosier
    1
    Dec 4, 2002
    What is the fish scale method? If it means attaching a fish weighing device onto the end of a wrench and pulling 3.9 to 5 lbs. of weight, then the length of the wrench is a logistic imperative.
    In the absence of a torque wrench I always tighten until I feel restriction , while turning the wheel ,then back the locknut off until the wheel starts to roll freely,then grasp the tire at the top and check for any looseness by pushing in and out on the tire. If all of this is satisfactory insert the cotter pin into the nut and you should be good to go. Wheels should be checked periodicly for any looseness.
  7. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    Actually, I was wondering if there is a number for the wheel bearings, similar to the knuckle.
    Now I'm a little worried about the knuckle. I read here:
    http://disc.server.com/discussion.cgi?id=47751;article=99566
    that the knuckle should be 8 to 12 pounds. Mine is around 8, but I thought that felt a little tight. Should I re shim it?
  8. darkman
    darkman
    91
    1
    Jul 22, 2002
    Trevor
    My reference (repair manual) has it at 3.9 to 5 lbs for knuckle bearings. That is what i thought that you were refering to.
    I haven't heard of a similar method for wheel bearings.
    For wheel bearings I use the old method of tightening the inner adjusting nut until the bearing is fully seated while turning the disc by hand. Then, backing off the nut 1/8 turn, reassembling, and checking to ensure that there is no play in the bearing. None of my references have a specific tourque for wheel bearings.
    Mike
  9. Bama_B
    Bama_B
    37
    May 17, 2003
    3.9-5 lbs is all you need on the pre load (or so says the friendly Toyota man)...
    Not to beat a dead horse (or separated birf, as it were) but 1.5 in Sch 80 PVC (black) works best for separating axles by the pipe method. It doesnt deform or crack nearly as bad as the Sch 40 (white) pipe will. Remember to stuff a rag in the bottom of the pipe to prevent damage to the inner axle splines. Learned from anothers bad experience. :stupid:
