Anyone have any good [non-remove/seal up] advice for quieting the sunroof down? it rattles.
Hey they are still made or available... I just replaced all the sunroof trim bought it at camelback toyota phoenix.. about $100 for all 4 trim pieces with the copper state cruisers discount they offer..(thanks Murph) .... only gray color available though... so I sprayed it to match my tan interior which should hopefully give it a layer of UV protection ... yes the old ones where extremedly brittle fell out in 1,000,000 pieces once I messed with them... The new ones where much more plyable and did stop most rattles but not all.. So im still interested on how to stop the rattle caused with the cover and wind deflector.Be careful of the covers, they are extremely brittle and no longer made by Mr. T. from what I understand.
For what it's worth, mine stops rattling if I hit the 'tilt up' button for a split second and leave it in place. Just enough to not be fully seated down, but not enough to leak air/water. It's not a permanent fix, but might work for those just looking to make it through to warmer months when it's easier to tear into the vehicle.
I'm experiencing rattles in my sunroof also, in the front corners (both sides) that are worse in cold weather. I believe my rattle is coming from the wind defector when stowed. There are five black foam rubber pads (isolators) that prevent the two deflector arms and deflector from making metal to metal contact.
