Kaymar Rear Bumper
Discussion in '80-Series Tech' started by jyoun02, Apr 2, 2003.
  1. jyoun02
    jyoun02
    21
    1
    Mar 27, 2003
    Anyone here running one of the kaymar rear bumpers on their 80? I'm considering purchasing one, but I would like to get some opinions first.-John
  2. Wrench
    Wrench One Bashed Up 80
    4,490
    176
    Mar 27, 2003
    If you plan on wheeling your 80 then don't get the Kaymar. It has a horrible departure angle. Look a Slee's instead if you want to wheel your 80. It is designed for wheeling.
  3. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    From what I have heard about the Kaymar it is built for wheeling, but maybe not for rockcrawling. It seems that most of what is built for the later Cruisers is geared towards expedition type wheeling.
    Expedition type wheeling is in my opinion the best and most fun type, but I don't know how to wheel like Wench. :tear:
  4. landtank
    landtank SILVER Star
    18,416
    594
    Mar 27, 2003
    Groveland MA
    I'm with Rogue, I've got the Kaymar and haven't had any issues yet. It doesn't seem to be as strong as Slee's where the bumper returns to the wheels but gets the job done for quite a bit less money. I got the double pin delux bumper with one tire carrier for 300.00 less than Slee's. The bumper bolts flush to the rear crossmember so unless that is cut off before installing Slee's I'm not sure how the departure angle is improved.
    Rick
  5. yomama
    yomama
    291
    Mar 27, 2003
    jy,
    Nothing wrong with the Kaymar, you can see it at http://www.yomama.net. I like it and it is rated at 7k towing, not sure what Slee's is.
    Yomama
  6. Strider
    Strider
    47
    Mar 28, 2003
    Yo, the link didn't work for me? site down?
  7. yomama
    yomama
    291
    Mar 27, 2003
    Yes, :dunno: what the deal is or maybe I do, Microsoft :mad:
    I guess I will have to sit down with my friend :beer: and get it up and running again. Check again tomorrow....
    Yomama
  8. Wrench
    4,490
    176
    Mar 27, 2003
    Jealousy will get you nowhere..... 8)
  9. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    OK, we sell all three bumpers, Kaymar, TJM and ours. So I think I can be impartial :D
    Kaymar is a great bumper for towing & expedition wheeling, but it does hang lower down below the cross member, although it does wrap the rear of the crossmember the same as all the others. It is mostly the receiver that hangs down. Also, it does have two pivots which allows you to take the whole house with you on said expeditions. The wing supports are not great, and the corners are big, boxy and low. The tire carrier is not bad and will accomodate a 315 tire.
    The TJM is a lower cost option, can be had with two carriers. Also, the hub is built into the bumper, so when you have no carriers, there is no spindles sticking up. It does have nice rubber caps on the ends and the corners are pretty small and tucked up. The wings are not very strong and the supports are also not that strong. The bumper wraps the crossmember, but the bottom is not turned in again. That leaves a lip that can catch and bend when you drag it over rocks. The tire carrier sits fairley low on the bumper and you can not run a true 35" tire on it without modifying the mounting piece. No receiver but the holes are left open on the back of the crossmember.
    Slee bumper, it only comes with a single carrier, but it is high mount and takes a 37" tire. The wings are strong and well supported. No receiver, so if you tow 6k lbs all day, it is not for you. The corners are tucked up high and have about 3" more clearance than the Kaymar. The bottom lips are all turned in, and you don't hook it when you drag it off rocks.
    Custom, well that is always the best since you can get exactly what you want, except in most cases, the cost would be a problem, unless you have a buddy that will make it for :beer: money. Or you have all the tools & stuff and want a fun project.
    Hope this helps.
  10. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Christo,
    What's your brand :beer:?
  11. sleeoffroad
    6,056
    531
    Mar 27, 2003
    Cruiserdan, I preferr the darker ales and such. But being from South Africa, most of us are brandy & Coke people 8)
  12. cruiserdan
    20,603
    2,978
    Mar 27, 2003
    See ya Saturday......Bring your welding hood, I'll bring the ice chest :beer:
  13. TucsonCruiser
    TucsonCruiser
    48
    Mar 27, 2003
    I should know this since I have one ::), but Christo is there a way (i.e., a way for a guy like me who isn't a machinist) to mount a gas can to the rear bumper/tire carrier?
    Where else are folks mounting those besides the back bumper/tire carrier? Roof rack?
    Thanks,
    Simmons
  14. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Roof rack is not a very good option since its puts too much weight too high. My 4runner friends do it cause it looks good :slap:. Best option would be to buy a bumper like the TJM, Slee, or Kaymar.
  15. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Simmons, I recall seeing a rear spare tire mount in the SOR catalog for a single gerry can.  I'd be willing to bet that your Slee carrier could handle the additional weight.  You might want to check that out.  I've seen similar items on Jeep websites, too.
    -H-
  16. TucsonCruiser
    TucsonCruiser
    48
    Mar 27, 2003
    Attached to the spare tire would be a little awkward, since on the Slee carrier that's where the license plate goes:
    [​IMG]
    I'm thinking on the top of the left side of the bumper---but don't know if there's a Slee-designed holder. Christo still here?
  17. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    You wouldn't have to carry it all the time, just when necessary. To relocate the license plate would be the simple part, just get some bailing wire....
    BTW, we need to get some Arizona pinstriping on that rig--much too pristine. A nice tight trail or two in Sedona would be just the trick. :eek:
    I've debated about putting a couple of can mounts on the rear quarter panels, with bracing from the inside, but..... :slap:
    -H-
  18. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Put them up on top. You never know when you may need an extra 40 gallons.
    Bill
  19. cruiserdan
    20,603
    2,978
    Mar 27, 2003
    Bill,
    Show 'em the CRANE.......... :bow:
  20. Photoman
    1,145
    Media:
    41
    47
    Mar 28, 2003
    There were two mounted spares on top and I made this to raise and lower them from the rack. Dan wants to buy this from me - something about his bedroom. :D
