Just barely staying alive at idle, full throttle
Discussion in '40- & 55-Series Tech' started by JohnL, Aug 20, 2003.
  1. JohnL
    JohnL
    358
    1
    Jul 2, 2003
    Thanks to all who helped get my new Painless harness and DUI distributor dialed in. It started right up. Went for a long ride and after sufffering some occassional and intermittent backfiring, decided to take it home and maybe retard the timing just a degree. It was running strong.
    I went to go start it up and found it wouldn't start , only a cylinder half firing and then dying. Found that my starter solnoid was bad (can you rebuild those?) and replaced it with a gear-reduction unit I had lying around. Now it starts fine, but it barely stumbles along its idle. It will half-heartedly rev up when it is floored (to a max of ~2000 rpm) but will stall or barely idle again when accelerater is let off. It cannot muster enough torque even to roll forward a few feet. It just stalls, even when revved.
    The carb was rebuilt a few months ago, but I haven't looked inside yet. Possibly a bad fuel filter??? I'll go replace that in a few minutes, when the garage is slightly more aired out.
    Any theories? I will, of course, check the static timing again...
    Thanks all
  2. offcamber40
    offcamber40
    279
    1
    Apr 26, 2003
    Mountains of WV
    Re:Just barely stumbling at idle
    Maybe a vaccuum leak? I would check your vacuum ports and lines. If it is a vacuum leak, it would probably be a big one and noticeable they way you described your running problem.
    Mike
  3. JohnL
    JohnL
    358
    1
    Jul 2, 2003
    I don't have any carb cleaner here to check,
    ...but I highly doubt any problems with lines (I JUST replaced them all, none kinked or old) or ports (they all look good.) I would have suspected a vacuum leak to come on more slowly...running perfect one day, barely alive the next.
    Changed the fuel filter, same results.. ??? :mad: ??? :mad:
  4. JohnL
    JohnL
    358
    1
    Jul 2, 2003
    Got it on my own damn self
    Plugged fuel filter and too-rich idle mixture screw.
