Joining copper to stainless steel
Discussion in 'Expedition Builds' started by TheJackRabbit, Aug 4, 2009.
  1. TheJackRabbit
    TheJackRabbit
    650
    14
    Sep 21, 2006
    Sangre de Christo Mtns of North Central NM.
    what are some good leak proof ways of joining copper pipe to a stainless steel tank? Not much pressure other than gravity feed and temperature around 170-190 degrees. Hot water feed for camping. I have a ss tank and would like to use copper tubing as I have a roll of it (1/2 inch).
    I have read that ss will reject the silver solder used for sweating copper pipes. Alternatively, the welding rod for stainless steel requires so much heat it will likely melt the copper tube. So, what are some good ways of making leak resistent joints?
    Thanks in advance.
  2. askeyey
    askeyey
    346
    1
    Nov 17, 2008
    Watertown, NY
    You might try a "shark bite" style fitting for the copper pipe...it presses on to the end of the pipe and provides a water tight seal. ( no leaks in my bathroom in 3 years)..the other end of the shark bite can be pretty much any fitting the manufacturer has, but I would go with a threaded one that your could mate to a stainless steel or perhaps PVC fitting to affix to the tank...the pvc would be like the style you see on farm water tanks that have a gasket and ring for the inside of the tank and a gasket and fitting on the outside...should work well..
    you can find the shark bites at home depot or lowes...
    SharkBite Connection System
  3. TheJackRabbit
    TheJackRabbit
    650
    14
    Sep 21, 2006
    I checked the website and it is interesting although I am not sure itwill work for my set up. We have nothing like Home Depot or Lowes for 130 miles, so will have to see what are local stores can come up with.
    Thanks
  4. doug720
    doug720
    2,401
    534
    Sep 27, 2008
    El Segundo
    Can you weld stainless? If yes, why not buy a SS flare fitting and weld it to the tank? Then use a flare fitting to connect the copper line? You can also get a o-ring sealed "Bulkhead" fitting and just drill a hole in the tank to mount. But, I think welding is the best.
    Doug
  5. Mace
    Mace rock scientist.. Staff Member s-Moderator
    20,236
    840
    Feb 17, 2002
    Las Vegas
  6. Bogo
    Bogo FOOF
    1,927
    131
    Feb 15, 2008
    On the farm
    I second this.
    If you feel you need for galvanic isolation, have a stainless steel FPT fitting welded to the tank. Then use a short nipple of high temp handling PVC pipe. Then use a brass compression fitting to adapt to the copper tube.
  7. Walton
    Walton
    688
    20
    Aug 7, 2006
    The Evergreen State
    There is absolutely nothing wrong with soldering copper tube to stainless.
  8. rusty_tlc
    rusty_tlc Dain Bramaged Member
    12,845
    Media:
    3
    508
    Jun 23, 2005
    Reno, NV
    It's all about the flux, you need a highly active flux in order to wet the stainless.
  9. Dirtsquirt
    Dirtsquirt
    293
    May 10, 2008
    Spokane Wa.
    x2 on the brazing
    silver bearing solder and a good flux will the job nicely.
    did it all the time in the military with Wexler fittings (300 series Stainless) to Schedual L copper tube.
    Saftey-silv 50% silver is what we always used. I actually considered brazing at the temps of this product.
    Staybrite 8 can be done with map gas and should do a fair job
  10. JohnR
    JohnR
    244
    Jun 18, 2011
    Laredo, Texas
    Brazing (silver or sil-phos) would probably be the best bet.
