It's that time... clutch cylinders
Discussion in '40- & 55-Series Tech' started by craigwanderer, Dec 24, 2011.
  1. craigwanderer
    craigwanderer
    254
    Sep 18, 2009
    NSW, Australia
    Yes, It's Christmas (Happy Christmas MUD! :) ), but it's also the time my clutch slave cylinder crapped out on me.
    I've never swapped out a master and slave before, and looking around on the intarwebz from google search to youtube, I can't find a tutorial specific to a 79 BJ40.
    Any words of wisdom or lookouts - or even better, detailed instructions ;) - on swapping the slave or both the master and slave would be most appreciated.
    After reading about potential problems folks on MUD had encountered with their 40s I bought a bunch of spares earlier in the year just in case, including an OEM clutch slave and master. So I have the tools, I have the parts, I have the fluids, but I don't have the knowledge.
    An assist to this mechanical noob would be appreciated.
  2. Josie'sLandCruiser
    Josie'sLandCruiser Stop calling it a "FJ." SILVER Star
    5,028
    Media:
    10
    99
    Feb 4, 2005
    Seattle, USA
    Hi All:
    Do you have any Land Cruiser manuals?
    The factory Toyota manuals are best. The Max Ellery and Gregory's manuals are pretty good. The Haynes manual is fairly lame.
    Swapping the clutch master and slave cylinders is pretty straight-forward:
    A) Drain the clutch system.
    B) Detach the clutch hose from the master cylinder.
    C) Remove clutch master & install replacement.
    D) Re-attach clutch hose.
    E) Detach clutch hose from slave cylinder.
    F) Remove slave cylinder & install replacement (be sure the activator rod is the same length.)
    G) Re-attach clutch hose.
    H) Add clutch (i.e. DOT 3 brake) fluid and bleed system until good clutch engagement/pedal pressure results (gravity bleeding can work quite well.)
    Good luck!
    Alan
  3. edwjmcgrath
    edwjmcgrath
    2,767
    Media:
    1
    156
    Sep 14, 2009
    North and South of Mason Dixon
