It's not cast iron (2 Viewers)
FWIW, after I bought my deBuyers, I haven't used the cast iron since.
X3.
Just off the Rubicon trail for 7 days, the DeBuyer 12 inch got a good work out.
I would like a steel pan similar to the one described by Horace kephart
I don't see how the one pictured would work unless there were a wing nut or something to hold the handle in position when unfolded.
That 12.5 is calling my name!
never...
My wife got onboard with the CI concept but couldn't deal with the weight. Ordered a 12" carbon steel pan along with some other goodies today. I'm afraid this is going to put my CI fetish to rest...
Cook her a rib eye in a cast iron skillet, Alton Brown has a good video on how to do it right.
Ok I know it already says somewhere in this thread, but I don't wanna go looking for it. What is the best/fastest way to strip this pan so I can re-season so my wife can use it. Also is it say to use a skillet on a glass top stove? Thanks all!
-Daniel Kent
-Daniel Kent
Wire wheel the whole thing if you're going to start over.
Yes it's safe to use on a glass top stove (I do on mine) provided the bottom of that cast iron pan does not have any burrs or sharp edges on the bottom.
Sweet! I'll get right on it. Best way to season it? I know their is a ton of options on here! Preferably one that doesn't involve animal fat (thought I saw that as an option). We eat plant based (no animal products). Thanks all!
-Daniel Kent
-Daniel Kent
I think I ended up using 300* as an oven temp to cut down on smoke, but YMMV:
http://bfy.tw/w6R
^Thx! I goggled it, but really wanna use a method a fellow mudder recommended. I'll check that one out!
Are those hair line cracks I see?
Personally, I like the handles better. It seems to heat more evenly too.
My 10" steel pan sees a lot of use because of the weight issue.
