Lock up is when the tranny "locks" into overdrive which occurs around 52-54 MPH. You should see the tach drop.
I haven't seen anywhere on how to adjust the kickdown cable. Is there a post I'm missing? How do you do it?
The way I did is adjusting the idle RPM and Max RPM as they were way offset. I found the procedure in the engine (2H in my case) FSM.
Would you get the Rapid Cool cooler even if its only 11"x11"???
