impact sockets vs regular sockets
Discussion in 'Tools and Fabrication' started by CELICA XX, May 23, 2010.
  1. CELICA XX
    CELICA XX
    227
    1
    Apr 14, 2006
    Tulsa, OK
    I need to buy a set of bigger sockets 19, 21, 22, 24, 27, etc... and I thought about buying impacts.
    I've been wondering if impact sockets should ONLY be used for their intended special application of impact torquing.
    Is the material of the impact socket less brittle but more malleable ?
    In other words, if I use the impact socket for regular bolts on a breaker bar, is it going to deform or damage the socket in any way ?
    Thanks.
  2. Wile E Coyote
    Wile E Coyote Dave's not here! SILVER Star
    3,175
    Media:
    9
    38
    Sep 20, 2005
    Western AZ
    Buy the impacts and use them with your breaker bar. No worries. The only limiting feature I can think of would be impact socket wall thickness making engaging a fastener tight to a corner a hassle.
  3. Joe_E
    Joe_E
    3,550
    Media:
    39
    126
    May 31, 2008
    the NJ word..
    Always use the six point impact socket to remove the fill plug on your axles.
  4. Rambrush
    Rambrush
    374
    5
    Nov 7, 2009
    NW Az
    Like posted the Impacts are the way to go, however if using OEM wheels. Some have tighter/skinner holes and the impacts wont fit in and you would have to use a 6 point std deep socket.
  5. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,122
    Media:
    180
    234
    Mar 31, 2006
    Central California
    As mentioned, when you get to the larger sizes, they are thick.
    You have the larger sizes in mind but I do not think you pinion flange or the rear drive shaft flange on the T-case allows for a thick socket.
  6. AShoe
    AShoe
    209
    Aug 19, 2009
    Ft. Collins, Colorado
    Unless you have a big impact wrench just get regular sockets. My 500 ft/lb impact wrench just gathers dust because 9/10 times it won't do the job. I would trade my 1/2 inch impact set for a 1/2 inch 6 point regular socket set any day.
  7. spressomon
    spressomon glutton Moderator
    12,051
    Media:
    13
    631
    Jan 9, 2005
    Everywhere
    Impact sockets are slightly softer than regular hard chrome sockets. This is to protect the impact wrench square drive mandrel. You can cheat in a pinch, as Ali showed me, by using a short impact extension with the hard chrome/standard sockets. Yes 6pt on impact.
  8. KLF
    KLF Frame waxer SILVER Star
    6,271
    473
    Apr 5, 2003
    Southern NH
    This may seem like a good idea until the impact gun shatters the socket and blows sharp metal chunks into your face. Seen it happen.
    There are a few times when an impact socket won't fit, such as the 32mm nut on the t-case output. Otherwise I always use them with my gun.
  9. Rambrush
    Rambrush
    374
    5
    Nov 7, 2009
    NW Az
    There are those times when you have to use a Std 6 pt socket. I have used a quick wrap of Duct tape around the socket. This helps contain the shrapnel if it should shatter.
    Not saying this has to be the way but in a pinch you have to do what you have to do.
  10. Tools R Us
    Tools R Us
    20,132
    1,466
    Jul 20, 2004
    Chandler, AZ
    Correct, chrome sockets are slightly harder, but it's the chrome that causes the majority of the anvil wear. For home/occasional use it's probably not a big deal, in everyday use anvils get eaten pretty quickly.
    I'm not going to call total BS, but close.:hillbilly: In my experience have heard this tons of times and classify it as an old [STRIKE]wife[/STRIKE] mechanic tail. No matter how the load is applied, there is some risk of a socket failing, but have never seen/heard of a documented case of one failing with enough force to cause serious injury.
  11. Tools R Us
    Tools R Us
    20,132
    1,466
    Jul 20, 2004
    Chandler, AZ
    This one I have to call BS.:hillbilly: If your talking in context of this forum, Cruiser work, I can only think of a few times when I was denied with a good 1/2 gun. In fact most of my Cruiser work is done with a 3/8" gun. Ether your "500 ft/lb impact" is wimpy or your being denied working on heavier equipment?:hillbilly:
  12. fj40charles
    fj40charles
    3,040
    195
    Dec 7, 2002
    Texas
    What brand/model 1/2" impact are you using?
  13. romegadave
    romegadave
    1,276
    20
    Feb 26, 2008
    rome, georgia
    I've got the bigger Husky's at Home Depot........69.95 for 11 sockets.
  14. neufab
    neufab
    30
    Sep 15, 2008
    inland empire
    i have several impacts,and sad to say my 20year old alltrade has never let me down.iv'e rebuilt my snapon 2 times,craftsman 2 times and is broke agian.bought the old alltrade for 4.99 at picknsave.whats funny is the houseing is interchangeable with the $$$$ snapon.6pt will usually do the trick w/out impact.rember to allways use antiseize.sorry for the ramble buy bolth.high qualty thin wall.impact could probly get buy with harbor if budget wont allow high quality.
  15. AShoe
    AShoe
    209
    Aug 19, 2009
    My impact gun doesn't move the bolts on my tractor (some call for 1500 lb/ft). I don't use it on cars, too many broken bolts.
  16. fieldsken1
    fieldsken1
    2,569
    Media:
    108
    24
    Nov 6, 2007
    in my little world
    if you go to sears and buy regular sockets use them cheaper and thinner but still guaranteed so no biggie if you break them you always get a new one
  17. Radd Cruisers
    Radd Cruisers
    7,927
    60
    Sep 28, 2002
    Vancouver Island BC Canada
    :popcorn:I purchased Jet sockets then later upgraded to Mac sockets, much smaller and fit into tight areas.
    Rob
  18. Sc0-
    Sc0-
    1,098
    Media:
    2
    9
    Jun 8, 2007
    Houston
    Agreed, not all impact sockets are alike. Some brands of sockets have thinner walls than others, Snapon, Mac, Matco, I/R might fit into a tighter spot than the S&K, Sunnexx, gray pneumatic, harbor frieght, Northern Tool, etc.
    I have used a few chrome sockets for items when I was in a pinch. I have noticed that for some reason the chrome socket was NOT able to remove a fastener but a impact socket did.
