- Thread starter
- #161
You're right. It's easier to find a president without a brain than a battery charger without one. I have a nice big heavy old charger that was used to load truck batteries. When I did the bigger parts like the front bib, radiator surround etc I just packed some bricks on the floor and then put a double layer of heavy duty plastic sheeting used under concrete floors over that and then poured the mix in that. You can;t do that if you got kids around.
What I'm planning to do is to use 2x4s and shutter board to make a tank and then line it with the same plastic. Once the cleaning's done I can just disassemble it and store it away till next time. Most of the stuff will fit nicely into a plastic 200 litre drum.
The article I read that impressed me most was written by a guy who does marine salvage work. He has done complete marine engines and gearboxes that had been under water for decades and got them turning and restoreable again without taking them apart first. Just some time and electrolysis. He recommends a battery in the system between the charger and the anode/cathode.
I also want to make a plating set-up. My new mate, Kobus, who is a professional restorer has one that he made himself and does all his own stuff in-house instead of sending off to Johannesburg 600km away. Only the chroming goes out. He says it's easy to make and do. Old dogs learning new tricks....
