Ignitor
Discussion in '80-Series Tech' started by landtoy80, Jul 27, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I don't know what it does but I have one from the 87FJ60 from the HEI dist swap. What does it do? What part of the HEI Dist replaced the ignitor?
    Could the FJ60 ignitor work in the 80's went out?
    kurt
  2. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Kurt,
    Not sure I can answer all your questions...speaking from butt:
    An ignitor, if I'm not mistaken, is basically a solid-state replacement for the points/condenser, and would typically fit inside the distributor (at least the ones I've seen do).
    I pretty sure an 87 did not come with an HEI distributor--that would have been a mod. Ignitor, if present, would have replaced points/condenser. So no part of the HEI replaced the ignitor--other way around.
    I'd be reluctant to put the 60 ignitor in an 80 (assuming you can)...
    Tom
