How to test/clean EGR
Discussion in '80-Series Tech' started by thelal, Apr 23, 2003.
  1. thelal
    thelal
    541
    22
    Apr 15, 2003
    was N of Seattle, WA, USA - now on 1 year 4x4 trip
    I've just taken off my EGR and wondering how to test/clean it.
    Should I use carb cleaner, rags, white spirts etc..
    Its pretty sooty but not bigs chunks of anything.
    Does that sound normal - all EGR/VSV pipes all seem to be clean and clear.
    <awaiting to put back on>
    96 tlc 80 with 83K
    Lal
    brendan.lally @mail.com
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    carb cleaner works well.
    Apply vacuum, if the pintle sucks up it's good. Check to see if a chunk of carbon is keeping it from closing, but yours sounds like that's not a problem.
  3. thelal
    thelal
    541
    22
    Apr 15, 2003
    Todd,
    Thanks - I did use carb cleaner if the end and that helped a bit in getting some of the soot off. It wasn't that bad but hard to clean due to internal shape. Checked rest of pipes etc. and put back on. All ok (problem turned out to be a loose IAC that once pulled the battery acted as a big vacuum leak - see 80scool list)
    Lal
