How to seal off sunroof
Discussion in '80-Series Tech' started by monster80, Feb 16, 2011.
  1. monster80
    monster80
    66
    Media:
    1
    Jul 6, 2010
    Kenya
    Dear All,
    I have a persistant leak from the sunroof of my 80, since I dont use it much anyway, was thinking of just sealing it off. I have read many posts of leaky sunroofs and would think to seal it off permanently would be a good solution.
    Would applying silicone do the trick? Anyone out there who has sealed theirs?
    I dont want to remove the glass, just seal off the gap between the roof and the sunroof glass/rubber.
  2. thestunts
    thestunts
    603
    3
    Dec 19, 2009
    Roseville, CA
    Silicon would work and some of have done it in fact. Search and it would prevail.
    I've personally taped it up. @ Wal mart, in the paint section for all the window crap, they have weather tape. It's clear and as wide duct tape .. it's for home windows and stuff. I bought that and just put tape over the edges ... Works well. Clear enough so you don't see it. Has been through the car wash a couple times with no problems either. If your concerned about paint ... maybe not a good idea. I'm not.
    Cheers
  3. MHTARSTON
    MHTARSTON
    236
    Dec 31, 2006
    South New Jersey
    Have you tried the trick by feeding electrical wire in the rubber gasket to make it expand and seal? This worked like a champ for me.
  4. joseywales
    joseywales
    304
    24
    Apr 16, 2006
    Roca Blanca
    Care to expand on this mod? Link to a thread?
  5. Schwein
    Schwein
    800
    Media:
    9
    6
    Jun 22, 2010
    Boston, MA.
    i used industrial silicon on an old jetta that i had to seal the sunroof off (for similar reasons) worked great, while your at it i would remove the wires that are attached to the sunroof switch, so nobody opens the roof and ruins all your careful silicon work!
  6. B Legit
    B Legit
    478
    3
    Mar 21, 2010
    Seattle
    I used black RTV gasket maker from napa to do this. It is holding up great and my cab is bone dry. I was planning on removing the switch connection as well. I could take a photo of how it looks if you are interested.
  7. jlg32281
    jlg32281
    2,014
    6
    Sep 15, 2006
    Vidor, TX
    is the sunroof on it's own fuse, if so, you could pull the fuse. if it's on a fuse with other stuff, then please ignore this comment.
  8. Hoosier Daddy
    Hoosier Daddy
    737
    53
    Jul 1, 2005
    CO Springs
    You've ensured the drains are clear and replaced the little plastic parts that warp and cause leaks, right? Or just looking to be done with it once and for all? Other than putting wire around the seal, some people have used a bike tire inner tube and stretched that around the glass under the seal. The net effect is to push the seal outward a bit and create a tighter seal. There are threads on this. I tried it on mine to stop a rattle. It ended up making the seal too tight (and did not stop the rattle), so I pulled it out.
  9. kbushnz
    kbushnz
    680
    34
    Aug 21, 2006
    Auckland, New Zealand
    My sunroof seals were shot and had huge gaps which water would pour in and over load the drains.
    So I masked it off 1/4 gap between roof and sunroof.
    Wiped in a bead of silicone. Not too much just a thin coat.
    Removed tape and left it to cure.
    Then ran a razor blade around it. In about the middle.
    Now I can open the sunroof and it has a tight as seal.....
    Cure in place seal.
    SmokingRocks likes this.
  10. B Legit
    B Legit
    478
    3
    Mar 21, 2010
    Seattle
    Mine would no longer pull all the way up and set level with the roof. Only operational fix would have been replacement which was more money than I cared to spend, so I sealed it up.
  11. skibob
    skibob
    136
    1
    Oct 15, 2010
    Oregon City
    Does the seal just wrap around the glass or is it glued on?
    Seems like the inner tube trick would be a cool fix if it isn't too fat to allow the glass passage through the roof opening.
    I just might give that a try tonight, the :princess: will be at the gym so I have a couple of hours quiet time to tinker.
    Nothing like working on the sunroof during a rainstorm.:bang::bang:
    If it works :beer: if not, :censor:
  12. BirfMark
    BirfMark
    453
    4
    Apr 15, 2009
    Ft. Collins, Colorado
  13. 80t0ylc
    80t0ylc Hill & Gully Rider SILVER Star
    2,322
    Media:
    18
    56
    Sep 24, 2008
    Canyon City, OR
  14. monster80
    monster80
    66
    Media:
    1
    Jul 6, 2010
    Kenya
    Thanks Guys,
    Currently I have taped it off using duct tape, however it disintegrates over a period of time due to heat and water, so I suppose silicone is the answer.
    Also the tape has helped get rid of the rattle, I just want to seal it off and be done with it, its so annoying to have wet seatbelts and a cold wet cabbin, esp in stormy cold weather.
    I would be interested to know if the sunroof has its own fuse so it can be disconnected.
  15. thestunts
    thestunts
    603
    3
    Dec 19, 2009
    Roseville, CA
    If you open up the "control panel", you can disconnect the switches.
  16. phatairman
    phatairman SILVER Star
    458
    17
    Apr 28, 2003
    Atlanta
    Replace the sunroof glass. That permanently fix my wind noise issue and water leaking in.
  17. beno
    beno Injection pump.... argh...... Supporting Vendor Moderator
    19,960
    Media:
    382
    8,354
    Aug 28, 2004
    Atlanta Megalopolis
    If you are really serious about permanently getting rid of the sunroof, I would take out all of the sunroof parts, sell them and get some money for them (they are really expensive new OEM from Toyota), and then go to a body shop and have them throw in some metal and weld it shut.
    Or, just throw a .50cal in there.
  18. LittleRock80
    LittleRock80
    901
    70
    Jan 11, 2009
    Little Rock, AR
    This worked for me as well. It's time consuming, and your hands and fingers are sore afterwards, but it does the trick.
    Jwp
  19. B Legit
    B Legit
    478
    3
    Mar 21, 2010
    Seattle
  20. B Legit
    B Legit
    478
    3
    Mar 21, 2010
    Seattle
    I do like the idea of mounting a Barrett M82 on top though.:D
