Had I known I would of had the screws and seal in hand years ago and did it as a PM with hopes of it going better.
So did yours go out big time, or did you just get tired of looking at it seep?
Only oil leak in the truck, I took care of the rear arch seal in the spring. I first thought it was the crank sensor but then figured it was the pump seal instead. It was only seeping but drove me nuts.
Absolutely, the oil pump seal, fasteners and the front crank oil seal. It's as open as it's ever going to be and the total for everything is most likely under $20.00.
I'm planning on starting this tonight - do I need to drain the oil?
What grit sand paper did everyone use?
