How to remove caked on grease
Discussion in '40- & 55-Series Tech' started by acjb, Feb 1, 2009.
  1. acjb
    acjb
    88
    May 3, 2007
    Birmingham, AL
    Just looking for some ideas on how to remove the caked on 30 year old grease on my tansfercase and transmission. I have not done much more than scrape the lumps off. I have sprayed with brake cleaner and other cleaners but that stuff is really on there. Any ideas on how to break it down or soften it would be appreciateed.
  2. friel01
    friel01
    424
    Nov 16, 2005
    Tucson, az
    not for aluminum
    not for aluminum, but for steel/iron, oven cleaner works great. Hit the local dollar store, pick up a case and go to town on the transmisison and engine, axles, frame, etc. Just keep it off the transfer case.
  3. Super Tico
    Super Tico
    19
    Jan 29, 2009
    Lake Arenal, Costa Rica
    Yellow pages.
    Heavy equipment repair or truck dealership.
    They have steam cleaners that ROCK :cool:
  4. ruthless79
    ruthless79
    122
    Jan 20, 2008
    LOUISIANA
    drag it to the car wash they have pretty good pressure on the rinse cycle or barrow a pressure washer and get some cans of foam engine degresserand soak it with that for a few minutes before you pressure wash it
  5. ocdbeetle
    ocdbeetle
    2,013
    Media:
    8
    2
    Aug 22, 2008
    Florence, SC
    X2
    The car wash here even lets me bring my little ramps that I can drive up so I can have some more clearance underneath.....
  6. jkl72-40
    jkl72-40
    1,071
    10
    Jan 28, 2006
    Scottsdale Arizona
    I had to use a piece of wood or a plastic puddy knife to getthe goo off mine. the car wash wouldnt even touch the stuff. then a wire brush after (not on a drill) then I could do the car wash thing.....
  7. acjb
    acjb
    88
    May 3, 2007
    Birmingham, AL
    Kyle,
    I think I am in your boat...that stuff is on there and I even struggled with the puddy knife. I will keep pecking away and then off to the car wash.
    Thanks
  8. Clutchee
    Clutchee I'm fun sized! SILVER Star
    3,533
    Media:
    16
    307
    Apr 19, 2004
    Hotel M-F, home weekends!
    Formula 409 & a wire brush, bristles need to be stout so you don't bend them but its worked well for me.
  9. fj404life
    fj404life
    1,356
    1
    Oct 25, 2008
    Central Oregon
    Best to go in stages...
    1st powerwash to knock loose stuff off.
    2nd take an old screwdriver/putty knife/wire brushes and pry/scrape the gunk off.
    3rd soak with gnarly degreaser of choice
    4th blast with power washer again
    5th repeat above 2-5 until you get it all (becuase there is no way you got it all the 1st time!)
  10. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    1. Get a cheap tank-type sprayer
    2. Fill with Kerosene(or Diesel)
    3. Spray liberally and let soak, spray, soak, etc, etc
    4. Try carwash or rent/borrow a Hotsey...heated pressure washer.
    OR.....in place of the carwash/Hotsey....a wire brush...cup brush on a cordless drill or angle grinder + SS wire tooth brush:hillbilly:;)
    GL
    Ed
  11. r083rt
    r083rt
    1,001
    Media:
    5
    38
    May 18, 2006
    Logan, UT
    Steam cleaners work great. Unfortunately from my experience you'll be hard pressed to find someone who will let you use one due to the environmental issues (the city wherein the company is located will often come by and and test the sumps for oil/grease). If you can find one great, but be prepared to shop around to find someone who will be willing to take the risk.
    Sometimes all it takes is a little elbow grease!
  12. webelk6
    webelk6
    1,228
    3
    Feb 27, 2006
    God's Country
    .2 could also be 100% mineral spirits. I soaked all of my axle parts in 5 gal buckets, and they came out like new. But it has to be 100% mineral spirits.
  13. friel01
    friel01
    424
    Nov 16, 2005
    Tucson, az
    proof
    here are before and after shots of a 1956 buick nailhead motor. Used about 8 cans of oven cleaner from the dollar store.
  14. jeffj40
    jeffj40
    186
    Media:
    3
    May 8, 2008
    New Jersey
    I had good luck with a fine wire wheel on my cordless drill while applying liberal amounts of straight dish detergent followed by a little pressure washing. Did it to a used tcase yesterday came out shiny and clean without toxic chemicals or oil to dispose of.
  15. Coolerman
    Coolerman SILVER Star
    5,621
    Media:
    2
    446
    Jan 5, 2004
    Paint Lick, KY
    If you are rebuilding the part then disassemble, scrap off as much of the grease/crud as possible, and throw it in the oven. Bake at 600 degrees for an hour, remove, let cool, and bead blast the remaining ash off.
    Powder coat extreme chrome with red highlights....
    Like this one...:grinpimp::grinpimp:
  16. FJ40zen
    FJ40zen SILVER Star
    989
    Media:
    22
    16
    Feb 16, 2007
    Fort Collins
    My favorite crud removal tool. ACE Hardware carries these. It will get almost any crack/crevice.
    Wish I had an oven. :hmm:
    [​IMG]
  17. makomark
    makomark
    118
    1
    Oct 21, 2008
    Davie, Florida
    Harbor Freight sells a sprayer that you attach to your compressor. I fill a bucket up with hot water and use this high pressure sprayer with a degreaser. It works very good. Although I usually hit it with a paint scraper first.
  18. acjb
    acjb
    88
    May 3, 2007
    Birmingham, AL
    makomark,
    got a part number on this sprayer? I have a big compressor and this just might help out. Thanks for all the replies.
  19. justweldit
    justweldit
    618
    Media:
    5
    Nov 11, 2008
    Clarkdale/flagstaff
    home depo carrys a cleaner degreaser zep purple degreaser . dont dilute put in spray bottle, just spray scrub rinse ,repeat
  20. NorCalBorn
    NorCalBorn
    1,862
    3
    Aug 31, 2008
    Pressure washer, :D Just picked up an electric one from Costco, less than $200, about 1500-1700psi and it works great. :)
    Side note, the word S C R A P E is a bad word in the forum...WOW!!, or it's just profiling the R A P E part??
    [​IMG]
