how to pull a carrier: ???
Discussion in '40- & 55-Series Tech' started by rusmannx, Aug 13, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    can someone explain this to me. i read the manual (green one) on how to do this, but i was only confused more.
    does the carrier come out the driveshaft side of the housing?
  2. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    Yes, it will come out of the drive shaft side. Are you doing the front or rear?
    Don't forget the rear has c-clips. It may be very hard to get it to come apart, but when it does be prepared for the weight.
  3. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    rear.
    i want to weld the spiders. don't i want to pull it out for this?
  4. 73lndcrsr
    744
    4
    May 28, 2002
    Sorry, can't help you there. I am sure there are several on here who can though.
  5. 72cruiser
    72cruiser
    2,709
    Dec 29, 2002
    nashville, tn
    read woody's tech article on welded rears.
  6. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i've heard of people welding their rear ends while the gears are still in the axle housing.
    what is bad about this?
    how long does it take to pull the carrier?
    do i have to slide the axles out?
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    I just did mine and it wasn't that hard. If you just read the manual you'll maybe have a tuff time making sense of it but if you use it as an instruction book while you do the job then things are less confusing. Woodys article is rather easy to follow. I have spares on the shelf so it was easy to take my time and go extra slow and careful. After welding one up on the bench and spending a lot of time cleaning it up I don't even want to think about how hard it would be to get it clean while still in the housing. I also wouldn't want to see what your ring & pinion would look like with all the spatter.
  8. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    will 7018 do the trick for welding?
    i also have some 6013 but i know that the 7018 makes a stronger weld. i don't know how good penetration will be.
    i've been fooling around trying to get used to this rod and been running it hot (145 or 160 amps).
  9. SpaceGhost
    SpaceGhost
    467
    1
    Feb 1, 2002
    Indianapolis, Indiana
    Weld it while in the rig. The only suggestion I have to add is get some splatter paste and smear it on liberally anyplace you don't want the splatter to cause a problem. Especially on the center pin. It's a pain to get it out later if you dont.
    Weld the small gears to the side gears, and liberally weld all the gears to the carrier where you can. Get it hot!
    This renders the third member/carrier unrepairable. Just make sure you can get the center pin, and block back out in the event you need to remove/replace and axle.
  10. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    7018 works well. IMHO Do not weld to carrier. I welded one to the carrier and it not only warped the carrier enough to throw it out of true, it is already cracking. I also did one Woodys way by not welding carrier. I welded the eight contacting points were the spiders and side gears meet. It is smoother, quieter, and not cracking. Thanks Woody!
