So I finally figured out how to do this. My first attempt failed when I tried to hammer an aluminum U-channel around a 1/4'' steel insert. It was a bitch to get the steel inner piece out of the formed aluminum and the aluminum ended up work hardening and started cracking. I never tried this process with a steel U-channel and may have had better success that way.
Instead I ended up getting 1/2'' x 1/4'' rectangular tubing from mcmastercarr and made the channels that way. Here is how I did it, you may find an easier way.
1. 6 foot rectangular channel
2. measure about 41 inches - you will shorten this up a little more later but you need this measurement for step 4
3. Drill bit (7/16th) - this is the size hole for the channel - you will need a smaller drill bit for a #4 screw for the actual door itself
4. drill holes in the channel about 6-9 inches from the edge of where your ends will be. This will help you bend the channel and will also double as the holes used by the screws
