77mustard40
Best wishes to the CO, you've got the right man for the job.
The 1mm OS used pistons came in the mail, they looked barely worn and are in the dishwasher at the machine shop now.
Curious what you would consider high mileage on a 2F? I don't have any post 7/80 2Fs but a bunch of earlier 2Fs. Was thinking I would be better off with the later ones but after reading about the heads cracking and living in AZ guessing earlier is better.
If you are asking about the head cracking issue, it doesn't seem to be just mileage. they have shown cracking with only 100K on a 1986 2F. And a 200K 1982 2F. and a slew of others I can't remember now. It really seems to be more of an age issue. It's like they hit their expiration date at 25-30 years.
This is odd to me, because I've always bought into the idea that if building a durable engine is the goal, use the oldest parts possible. A block or crank or head that is 20 years old and has 200K miles on it and hasn't cracked yet, is never going to crack. Machine the parts straight and they should be perfect forever, because they are totally stress relieved & happy.
FWIW, I consider hi miles on a78-earlier 2F to be somewhere above 100K. They don't last as long as the 79-later engines, due to their lack of oil cooler, poor carburetor & emision calibration, non-hardened rocker shafts, heavy valve gear, etc...
The 81-later engines seem to be quite capable of running past 200K with any kind of maintenance.
I'm gonna run mine until she quits and then it's getting a small block. I know, I know. I have been a 2F purist for a long time but a small block is so easy and cheap if you get lucky.
Can't wait to see how this turns out.
Might be a good point to bring up in the "Best 2F" thread.
I don't think lead had anything to do with compression, that would be octane. Lead was used to lubricate the valves, mostly the exhaust IIRC. JohnAre the F motors higher comp since they were from the leaded days. And the F 1.5 and so on?
Sorry for the off topic.
