Removing the smog pump will obviously require getting some things out of the way. I'm pretty new to working on my car, I've done the suspension, some exhaust welding, oil changes, etc and have had Gary Kardum do everything else, and I want to minimize the number of components I will remove but still remove enough to have reasonably easy access to the pump I'm working on.
I have read basically every thread about FJ60 smog/air pump elimination but I haven't found too much about how much disassembly will be required. The only real mention of this issue I've encountered suggested removing the fan and fan shroud.
For people who have done this and who appreciate my situation can you let me know what I should expect to be removing and any things to look out for in the process (don't let this touch the ground, keep track of that, etc.)
As a thank you I will document the process photographically and post it if it is actually successful.
Thanks very much!
Thanks very much!
